I'm looking at buying an R32 with an RB25 with a GCG highflow, 20det box and a heavy duty organic clutch. It is making ~220kw at the moment on low boost but is likely to make ~250 when tuned for 18psi. Will the box and clutch last if I shift slowly and smoothly? or will the power alone melt the clutch and then with a button the box?
Edited by Rolls
not 100% sure on the manual box but the auto with slight mods well handle up to 300kw easy! So if you dont start snapping gears and dropping the clutch while in higher gears then you should be safe man.
Prob better of "granny Shifting" til you further modify lol
