hey fellas....
my other thread was deleted for some reason and im yet to recieve a reason why, so heres the update to all who expressed interest....
kits are now available for immediate delivery for R32/33/34 GTST with GT-R kits following soon.....
there were about 20 of you who expressed inteerst when theyre ready, so please feel free to leave a reply here so that i may get in contact with you to arrange delivery/pickup
regards, aidan
https://www.sau.com.au/forums/topic/28832-oil-catch-can-kit-update/
  • Replies 47
You must have a short attention span....Forums were down for a while a lot of data was lost, your thread is probably in thread heaven. You need to repost pics and info :D
Like the others i'd be interested in how much...
these where th ones with the screw top lid weren't they?...
ahhh forums went down that makes sense...sorry i been away for a while. yep theres are the screw top items....already fitted to one sau car and a couple of s15's and have had nothing but excellent feedback. we have one on our silvia and s15 as well, they look fantastic.
ok im not sure how to post pics on a thread, can someone explain pls? or could someone host them for me? thanks....
how much are they
to post a pic u have to click on reply
then at the bottom there's a browse button
click on that to attach the pic then submit
pic cant be too big though or it won't let u submit it
I have had trouble posting pics ever since the site went down, just doesn't like it for some reason. I am still interested in a kit, when the GTR ones are ready let me know.
price is $265 inclusive of all fitting hardware/hoses/clips etc
to the GTR boys: ive not been able to work out GTR brackets as yet so if youre in melb, you are welcome to swing by the workshop one day to get a custom one made up, or else i can supply everything but the bracket for $10 less (you get own bracket made) let me know guys!
heres pics of in s13 and s15.....R33 is exactly same catch can assembly, but mounted to drivers strut tower....(identical to s13 basically except r33 piping much more direct)
  • 3 weeks later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
