I currently have a K&N pod on my 33 GTST. I want to change it to something else but i'm not sure what. I looked at a ARC cold air box. Also there was a carbon fibre one but i can't remeber what it was called.
Can anyone suggest any good ( or great ) cold air products ?
https://www.sau.com.au/forums/topic/288346-cold-air-induction/
The Just Jap ones or Unique Autosports ones are nice and fairly cheap. Can get them in carbon, fibreglass or stainless steel. That is just an airbox though, if you wanted an "induction" of some sort, maybe route some pipes to it or something. However the airbox on its own should be fine.
Edited by PM-R33
The ARC airbox is essentially the same as a pod. It just weighs a whole lot more.
If you have a Hybrid FMIC, then you can route a CAI into the unused IC piping hole, and get a CAB like suggested above.
But if your using a SMIC, or a Return flow FMIC, your only options really are the stock airbox, or not worry about the induction of heat.
I guess if you were keen, you could try modify an airbox to accommodate the factory intake snorkle.
