My R32 gt-r is fitted with Apexi twin pods.
They are due for a replacement as they are very dirty.
I don't see much benefit in them as I believe they just suck in all the hot air from the engine and would much rather prefer a standard (modified???) panel filter box as per the way the GT-r must have come in stock form.
Should I go down this path? or should I invest in building/buying a cold air induction box and replace the apexi pods with new ones?
You could just clean them.
I went from my Apexi pod setup in my R33 back to stock Airbox with Apexi panel fillter. Due to the same reason. Sucking in the hot air.
Should see you 300kw without hindering.
Also stops the annoying hissing they constantly do :)
many people have tested both and most have found that keeping a stock setup and perhaps changing to a k n n panel filter would be the best way to go about it and especially if you under the 350awkw mark.. they more for "show" really unless you build a proper box.. i'd keep stock, less attention from police too!
if you like the sound, keep the pods; i cleaned my mates apexi's with some dishwashing detergent in water...repeated step until clean rinsed many time in clean water n hung out to dry for four or so hours.
if ur tired of the noise like i am, going back to the stock box works nicely; there is a change in the feel of the power curve - more violent with the pods and more smooth with the box; i test drive the car on a cold night with the box, then changed to the pods and the feel is definitely there.
I prefer the pods for that nice noise n surge of power but the box soon as im only aiming for 170-180awkw
grab a stock box from the private classifieds, maybe odify it a tad as its not as free flowing as the r34 gtr airbox
Yeah, I quite like the noise too :)
Maybe I should just build a cold air box....
Are the pods illegal though? I thought you were allowed one mod for the intake and one for the exhaust?
What else did you mod? The FMIC is standard. So its hardly a mod :)
  • 1 month later...
yes it gets rid of most of it.
you will hear a little noise, but definitely not a WOOSH noise on boost.
i went from air box to pods, i initially liked it and so did everyone that i took in the car. but after a while i got sick of it, and mainly sick of explaining to the police that it isnt illegal. so i returned it to stock.
still is producing same power, it just doesnt go woosh then psssh anymore.
Brezza
pod filter are good for the first week if that, i was excited to hear the noise because its my first turbo and thaught it sounded good. got sick of the sound though, too much like a radio with no signal...
I just put a stock airbox back on after running pods for 5 years. Really don't lose anything except a little extra noise and just made 245kw at 14psi. As already pointed out the airbox is actually better unless you have a decent cold air setup and certainly helps in vic if you want less attention with respect to law enforcement :).
  • 2 months later...
  • 4 months later...
hey guys i got one of those stupid yellow stickers on my car but am having a hard time getting a hold of a stock air box for my r32 can any one help me out?
Put up a post in the Wanted to buy section. Thats how i got mine. In addition, look through the classified car parts section. You'll find one sooner or later.
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
