  • Replies 121
moar pics of legs!!! LOL
nice car mate. Get clear/smoked corners and LED tails quick...they improve the look of the car 100% ...also matt black or body coloured grills
this was my previous car with amber corners
and this is the same car with smoked corners and matt grills
Edited by fcruz3r
Damn that looks so much better with the clear indicators and those rims look good - still got them :P
I want to try and find some 330Ci headlights as they have the angel eyes + projector headlamps. Gota find a pair first though =\
nah mate. Sold those with the car. Only have the iforged equips. These will require guard rolling though coz they're 10 inch wide at the rears...in fact when I measured them....it was close to 11.5 inches lip to lip. Does make the car look tough.
Edited by fcruz3r
Just curious - how much would you be after for those rims with tyres? Whats the exact size, width, offset etc? PM me if need be.
Yes they do look shmexy on the Bimmer :P
Daniel - i can do more than 2 things at once :( lol
Roy - Whats the correct wheel fitment for the E46 BMW's? 5 x one hundred and what?
PCD 120 x 5, do not get commodore wheels coz they may have incorrect center bore size. You will need 72.6mm center bore for the BMW otherwise u might need to run hub rings which tend to break and even new ones have been know to vibrate under speed.
also for safe fitment (assuming 19" wheels), then 8.5 front with +38 and 9.5 rears with +42 will fit without rubbing.
The iforged are
19 x 8.5 and 19 x 10, iforged don't stamp offsets as they are all custom made in the US according to specs. They don't have rubber on them coz i reused the tyres. I'm looking at 2k for the wheels but I'm flexi on pricing, just hit me with a PM if you want to drop by my place and test fit them on the car.
Wont be for another 2 weeks though coz a mate borrowed them for a photoshoot and has them locked in his garage n gone on holidays.
If you like the look of the other wheels I had on my car ( the 5 spoke volk lookalike), I can send u a link to the dealer in the US. Easy ppl to deal with and good price on shipment too.
Edited by fcruz3r
Ok no worries.
I won't be looking at buying any rims within the next few months though. I have the transfer fees to pay and then i want to do HID's and LED's first. So I am just after a rough pricing guide on some rims+tyres so i know how much i need to save. I'll also be doing some dark tints before rims too.
I'll be looking at an 18 x 8.5 front & 18 x 9.5 rear.
Does anyone know where i can get some angel eyes? What i am really after (as stated a few times before ) is the 330Ci headlights (if i can find a pair....)
Ok no worries.
The 330ci headlights only came with Angel Eyes in the facelift models, so it wouldn't fit your car. if you get the prefacelift 330ci with projectors, you will still need to buy the AE's and fit them on.
Best option is to go aftermarket. Check out
http://www.carwear.com.au/E46%20Head%20Lights.html
Don't buy the projectors from the US as they have a different beam pattern and will be illegal here.
for LED tails, email [email protected]
http://www.euro-division.com/index.php/3series/e46/lighting
Ok, thanks for that.
I have heard of people installing the aftermarket headlights (AE/Projectors) & LED tail lights, and it causing problems with the electrical system/s?
No problems with the LED tails that I've heard of. There has been an odd complaint where it flickers...but that's due to a resistor pack going bad and is an easy fix (replace resistors)
Some CCFL Angel eyes have had issues with the connectors melting due to inferior design. Just splice the wires and use separate connectors + heat shrink. LED Angel Eyes have no problems.
You can get a bulb out warning when u swap out halogens for projector HID's. Most aftermarket BMW projector lights have HID Ballasts which draw close to 55w, so you shouldn't get a bulb out warning. If you do, then bring it to the dealers to get the LCM flashed and that resolves it. Buy from a reputable dealer and avoid Ebay to be safe.
Edited by fcruz3r
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
