  • Replies 121
moar pics of legs!!! LOL
nice car mate. Get clear/smoked corners and LED tails quick...they improve the look of the car 100% ...also matt black or body coloured grills
this was my previous car with amber corners
and this is the same car with smoked corners and matt grills
Edited by fcruz3r
Damn that looks so much better with the clear indicators and those rims look good - still got them :P
I want to try and find some 330Ci headlights as they have the angel eyes + projector headlamps. Gota find a pair first though =\
nah mate. Sold those with the car. Only have the iforged equips. These will require guard rolling though coz they're 10 inch wide at the rears...in fact when I measured them....it was close to 11.5 inches lip to lip. Does make the car look tough.
Edited by fcruz3r
Just curious - how much would you be after for those rims with tyres? Whats the exact size, width, offset etc? PM me if need be.
Yes they do look shmexy on the Bimmer :P
Daniel - i can do more than 2 things at once :( lol
Roy - Whats the correct wheel fitment for the E46 BMW's? 5 x one hundred and what?
PCD 120 x 5, do not get commodore wheels coz they may have incorrect center bore size. You will need 72.6mm center bore for the BMW otherwise u might need to run hub rings which tend to break and even new ones have been know to vibrate under speed.
also for safe fitment (assuming 19" wheels), then 8.5 front with +38 and 9.5 rears with +42 will fit without rubbing.
The iforged are
19 x 8.5 and 19 x 10, iforged don't stamp offsets as they are all custom made in the US according to specs. They don't have rubber on them coz i reused the tyres. I'm looking at 2k for the wheels but I'm flexi on pricing, just hit me with a PM if you want to drop by my place and test fit them on the car.
Wont be for another 2 weeks though coz a mate borrowed them for a photoshoot and has them locked in his garage n gone on holidays.
If you like the look of the other wheels I had on my car ( the 5 spoke volk lookalike), I can send u a link to the dealer in the US. Easy ppl to deal with and good price on shipment too.
Edited by fcruz3r
Ok no worries.
I won't be looking at buying any rims within the next few months though. I have the transfer fees to pay and then i want to do HID's and LED's first. So I am just after a rough pricing guide on some rims+tyres so i know how much i need to save. I'll also be doing some dark tints before rims too.
I'll be looking at an 18 x 8.5 front & 18 x 9.5 rear.
Does anyone know where i can get some angel eyes? What i am really after (as stated a few times before ) is the 330Ci headlights (if i can find a pair....)
Ok no worries.
The 330ci headlights only came with Angel Eyes in the facelift models, so it wouldn't fit your car. if you get the prefacelift 330ci with projectors, you will still need to buy the AE's and fit them on.
Best option is to go aftermarket. Check out
http://www.carwear.com.au/E46%20Head%20Lights.html
Don't buy the projectors from the US as they have a different beam pattern and will be illegal here.
for LED tails, email [email protected]
http://www.euro-division.com/index.php/3series/e46/lighting
Ok, thanks for that.
I have heard of people installing the aftermarket headlights (AE/Projectors) & LED tail lights, and it causing problems with the electrical system/s?
No problems with the LED tails that I've heard of. There has been an odd complaint where it flickers...but that's due to a resistor pack going bad and is an easy fix (replace resistors)
Some CCFL Angel eyes have had issues with the connectors melting due to inferior design. Just splice the wires and use separate connectors + heat shrink. LED Angel Eyes have no problems.
You can get a bulb out warning when u swap out halogens for projector HID's. Most aftermarket BMW projector lights have HID Ballasts which draw close to 55w, so you shouldn't get a bulb out warning. If you do, then bring it to the dealers to get the LCM flashed and that resolves it. Buy from a reputable dealer and avoid Ebay to be safe.
Edited by fcruz3r
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
