Jarrod19831 Posted September 17, 2009 Share Posted September 17, 2009 I need help with the missing part here, I have everything elese plugged in clock, climate control e.t.c and have this wire & connector left over. Can someone please help identify what part I'm miising. Thanks in advance Link to comment https://www.sau.com.au/forums/topic/288364-can-someone-help-identifying-the-part-im-missing/ Share on other sites More sharing options...
FLN75S Posted September 17, 2009 Share Posted September 17, 2009 I need help with the missing part here, I have everything elese plugged in clock, climate control e.t.c and have this wire & connector left over.Can someone please help identify what part I'm miising. Thanks in advance On my Series 2 R33 that was the aerial switch to drop it too half way or full length i'd assume it was the same in a series 1 Link to comment https://www.sau.com.au/forums/topic/288364-can-someone-help-identifying-the-part-im-missing/#findComment-4831351 Share on other sites More sharing options...
Count Grantleyish Posted September 17, 2009 Share Posted September 17, 2009 I'd say this part you're missing is a adjustment knob that adjust the backlight of the instrument cluster (that is what it is on my 33 S2). Link to comment https://www.sau.com.au/forums/topic/288364-can-someone-help-identifying-the-part-im-missing/#findComment-4831353 Share on other sites More sharing options...
FLN75S Posted September 17, 2009 Share Posted September 17, 2009 ^^^Well that confuses things a little then lol Link to comment https://www.sau.com.au/forums/topic/288364-can-someone-help-identifying-the-part-im-missing/#findComment-4831359 Share on other sites More sharing options...
blind_elk Posted September 17, 2009 Share Posted September 17, 2009 To confuse matters more, you may not be missing anything. The connector might be for something in another model (different models using same loom section). Link to comment https://www.sau.com.au/forums/topic/288364-can-someone-help-identifying-the-part-im-missing/#findComment-4832823 Share on other sites More sharing options...
ARTZ Posted September 18, 2009 Share Posted September 18, 2009 I got a s1 and there is noting there at all. just a platic plug to fill the hole most likely its a switch of some sort...join the wires somehow and see if anything happens... if not its probably for an acccessory you dont have like blind_elk said Link to comment https://www.sau.com.au/forums/topic/288364-can-someone-help-identifying-the-part-im-missing/#findComment-4834477 Share on other sites More sharing options...
Nic_A31 Posted September 18, 2009 Share Posted September 18, 2009 Rear wipers ???? Link to comment https://www.sau.com.au/forums/topic/288364-can-someone-help-identifying-the-part-im-missing/#findComment-4834517 Share on other sites More sharing options...
