hey guys,
upon inspecting the engine bay the other day i found this:
(sorry for the shitty phone cam pic)
the white/grey plug is disconnected and appears to lead to the aac valve
Is this done for a reason?
i connected it to see what happens and the idle goes all over the shop
should also note that at the moment when the a/c is on idle is a bit wonky (ie: when coming to a stop revs drop down to 500/600ish rpm and car almost dies, will also do this randomly when stopped at lights etc)
not sure if thats related at all?
car is automatic r34 gtt, 98 model
any ideas?
Cheers
Edited by stenve
https://www.sau.com.au/forums/topic/288424-aac-valve-disconnected/
It's possible been disconnected, because it's causing the ruff idle? Try taking it off and giving a good clean out. I've done this with r32's and it's helped clean up the idle. presume 34's are the same.
P.s. I'm having issues with my r34, and need to get hold of a tip 34. Could you do me a major favour. On the side of your intake there's 3 plugs, red black and silver. could you unplug the silver, and try start it? Would really appreciate if you could. understand if you don't want to. Thanks.
thanks mate,
i tried what you asked (disconnected grey plug) starts up first go and idles fine.
Edit: ok scrap that.
took aac valve off cleaned it out, put it back on and connected it.
it started idling at 2000rpm and i went "oh no"
then i screwed in the idle screw just a little and it dropped all the way down to 1100rpm
fine tuned it down to 800rpm and all is good (air con works fine etc)
problem solvered
Edited by stenve
i have the same problem stenve,
i just havent taken mine out to clean it yet.
ill be doing it tomorrow so hopefully it solves my problem too.
when started and car is cold, does your car idle funny or only when warm or all the time?
it idled fine with the aac disconnected. it just didnt compensate for things like ac when sitting idle at lights etc.
I only tried starting the car once with it plugged in and i cant remember if it was a cold start or what... but the revs were all over the place.
car is cooling down now. i'll go start it from cold again later and see what happens now its all clean. it seemed perfect when i checked it just before though
yeap cool, im pretty sure this is the problem on mine
cause i drove it for like a month with it disconneted, i didnt even know until i serviced the car and i noticed it.
pluged it back in and car idled lumpy and crap so i dc it, and idled fine but it would stall randomly when coming to a stop.
its connected back up now, but on cold start it idles funny but ok when warm, i had to play around with it to get it idling ok, not perfect tho.
Good to hear you got idle under control. Thanks very much for doing that check for me, although wasn't the answer I was looking for. I couldn't ask one more favour? Could you identify the colour of the wires that plug into it (not the engine loom side) And where they run too? A picture would be perfect, but again, mite be stretching ya a bit far. Sorry to ask of you again. Thanks
yeah mines still not idling perfect either, when in neutral its spot on 750rpm and stays there. put it in drive and it goes up and down a bit, esp with the ac on.
gave it a cold start this morning and the revs sit at about 1200rpm for a minute or 2 then drop down to normal.
might need a little fine tuning still, but it's alot better than before.
Mawzy: i'll try have a look sometime today. but its about a 11ty billion degrees outside. see how i go
:) This may be a bit of help if you've cleaned out you're AAC valve thingo (R34GTT)
double clic to enlarge then double click again to supersize
I think if you have a big zorst and/or pod you may find that even when set it'll still run a bit over the OE 650/700 rpm set level.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
