Well not yet but if i keep pulling things apart it might.....what i am wondering is..
.IS it possible to make 190rwkw and 600nm of torque with a standard 45v2 turbo 2 3/4 exhaust with 4 inch cannon apexi pod full of dust ,, 550cc injectors ?? fuel pump.. at 11psi with a bunnings bleed tap .the ecu says nothing other than re-manufactured and doesnt appear chipped though speed limiter is removed...
does this sound about right
or am i the victim of an over excited dyno...it was fairly new and power was applied liberally..i didnt buy anything of him either so he had no need to talk it up. i just paid 50$ for a quik run...power seems good but i have no idea where its coming from
Edited by doozooby
https://www.sau.com.au/forums/topic/288437-curiosity-killed-the-car/
Thanx mate..ill take your word 4 it then..I'm tired of thinking about it
I was told bigger injectors and the fuel pump had been done , he said 550 but wasnt sure..im starting to wonder if they were done at all......
I wish i just didn't care and could just enjoy driving it but i'm a bit of a tech head when it comes to whats in my machine
check the dyno run wasnt done in 3rd gear with shoutout mode off
a typical GTST with basic to very basic/mild mods can peak near 200rwkw in 3rd gear and give misleading results
its fairly normal to make 200rwkw in 4th gear with remap/ecu/piggyback and boost, exhaust, intercooler
the reason i say 3rd gear is - the torque is very high
my gtst with pfc, 3" exhaust, intercooler, splitfires, 12psi, aggressive tune and 4th gear makes around 190rwkw and 500nm ish
a 3rd gear run of my car would net well over 200rwkw and torque would be more and it would avoid stock ecu speed cut too
the reason i am so curious is that i was planning to do all the sort of mods u guys have done , but it appears the power is there already and i have no idea why...i bought it off a friend who imported cars .. he said dont worry just enjoy it....but its driving me bonkers... :) ..haha
it does have a lumpy idle maybe its got cams or something, or is this normal for cannon mufflers
Edited by doozooby
Thats what im trying to find out..think it must be...
yeh same happened with me, thought i had a stock ecu, car made heaps of power on the dyno (2 different dynos). Im pretty sure a stock ecu wont let u boost past 10 or 12? psi. I managed to get it to 14 and it ran fine, so its definately not stock lol
we could only get 11psi with a bleed valve fully open, maybe different now with the turbotech..guess ill just buy a boost gauge and play with it.. i wonder if it would run alright with a slightly bigger or hi flow turbo or would that change everything
Well I used the turbosmart valve and i got a guage so i put it up to almost 1bar, or 14 psi or so. Im running a hi flow turbo, takes the boost pretty well
:rofl2:
Awesome.. do you know one..whats there number?
What about the wrong dyno and a good operator?
Whats wrong mate did the dyno eat your car?..
Cheer up, the world is beautiful..xcept for mondays :O
Edited by doozooby
Yeah it probably would, but it would be maxing the afm out. your injectors (if they are 550cc) will take it, and hi flow's are good for 250kw, but i wouldnt go any further unless u wanna grenade it and collect it out of the exhaust
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
