when you say torque is meaningless ..how so?..
is that why everyone posts kw figures but nobody posts torque?
yeah i was told if i wired up two afms so the ecu was tricked to think it was one it could work, however i just figured this would make the car run rich , thinking it was getting twice as much air as it was...which of course i didnt want to do
i have seen it done, but only on cars running management
Edited by doozooby
torque at the wheels is different in every gear too. you'll have a lot more in 3rd than in 4th. so unless its corrected to torque at the flywheel by calculation its fairly useless.
you cant run 2 afm's with the stock ecu
Have you just looked at the outside of your ecu or have you pulled the cover off it?
Also lets not forget that there are some "happy" dyno's around, if the one you were on is a happy dyno it could be reading 10-20kw higher than it should, where did you get it done?
If you have a look in the rb25 upgrade thread you will find people with your same set up doing similar sorts of power so its far from out of the question, as i have found tho the limit of the standard injectors (if they are standard), fuel pump and afm is around 200rwkw, im doing 210rwkw with the injectors seeing 100% and the afm tuned to 110% so if you go a hi flow you will need to upgrade all of these and your ecu, plus a fmic if you are still running the standard one.
Changing the ramp rate on a dyno can change torque readings. As will other factors.
The true test is the 1/4 mile.
yeah , apparently its run 12.4, on stock street rubber, soon as calder opens im gunna go find out for myself i think..might have just been a flukey run..or had a a tank full of metho...lol
we opend the ecu up all appears normal,although the sticker on the side says re-manufactured nissan ecu, i havent been able to compare it to any others ..if anyone has pics of a stock label on theres would be interested to see
The dyno seemed pretty legit, it was run a year earlier and pulled over 200kw so im guessing that was a happy dyno...and they were throttling it alot harder..
Edited by doozooby
dont mean to be rude mate, but if the car is performing how you want it, and drives how you want it to, and you happy with the power and torque of the engine, why do you care about a dyno print out? do what your mate said, and enjoy it! who cares what a dyno says!!
agree 100% with adamskill... dude if its got good A/Fs and is fast point to point. just love it :D haha
Righton fellas, the more i been yabbering on here the more i've realized, who cares ..i love driving it, unfortunately theres not the room or oppurtunity to drive it the way i would like..
on the roads so i think my best bet is to get to the track and just enjoy it for what its worth..learn some new skills
Its not what you got on paper but what you got on the tarmac that matters.
Now i just gotta put me car bak 2geva n hope she works again
Just for the record the A/Fs were purrrfect :D Cheers
good idea mate. ill give you the hot tip tho, all the bull shit on this forum about dyno's goes strait out the window when you take ya skyline to the track and realise that ya 10-15 year old car has brakes that dissapear after 2 laps, suspension that is sloppier than porrage, and tyres that loose traction mid corner and spin ya into the dirt. then u realise that dyno's mean absolutley sweet f**k all. rant over. have fun mate!! adam
You never mentioned if it has a fmic, if it hasnt then i wouldnt take it to the track without one, would hate to see your inlet temps after the first lap.
no it is on my list of things to do along with new tyres. and an oil change..lol..
if you have a spare one laying around ill happily take it off your hands :D
i do actually, hks one in fact, has the bottom plate bent but no damage to tubes, i'll dig it out and take a pic when i get around to it.
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
