Today we will be datalogging and publicly reporting on the new Cobb Tuning upgrades to the GTR which we have been providing input for over the past month. The brainchild of John in the UK and Joe from Cobb, the new mapping system does away with Air Flow Load inferred Wastegate Duty Cycle, and converts the R35 Boost Control system over to an RPM vs Duty Cycle output curve. What this means -
Stable boost control without the big boost spikes on 'flat foot' gearshifts that haunt most GTR tunes (no good for engine or transmission)
The ability to hold more consistent and greater boost pressure in the top end of the rev range.
No need to change over wastegate actuators on the GTR to higher rated versions
No need to add aftermarket boost controllers etc.
An exhaust equipped GTR using this mapping with stock actuators and boost control hardware just went 10.8 at Santa Pod a few hours back :P
We will be performing some mapping and datalogging using our new Mainline AWD dyno to provide the most consistent and repeatable data that we can give back to both Cobb and present to the public before the software is released. Exciting times ahead for GTR owners, and obviously we are happy to be part of the professional testing and development team for Cobb ;)
https://www.sau.com.au/forums/topic/288489-new-cobb-tuning-maps/
This is interesting.
At a recent practice day (Oran Park) running an AP tune, i found my lap times actually went slightly backwards. Personally, i think it was due to the power coming on too strong, too quickly, turning the tyres and invoking power sapping traction control. I guess the solution is to drive with TC off, and anticipate wheelspin more delicately, however something that guarantees a better/smoother and more progressive application of power may just turn that situation around for me.
Edited by LSX-438
Linear power that doesnt upset the balance of the chassis has always been the key.
I have never been one much for a big midrange rush than a curve that falls flat on its face. Great for the odd squirt between the lights (if anyone actually does that kind of thing anymore) but no good for a genuine motorsport application :O
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
