Millenium Jade R32 Skyline 140,000 k’s currently making in the vicinity of 300rwkw. The car will be tuned next week so an exact figure will be confirmed. At last tune it was 314rwkw.
It is a full on performance car and would be very dangerous in the wrong hands. It really is a handful to drive if pushed but is fine in traffic and had been daily driven by me since buying and modifying it. It returns 400+ km’s to a tank and is comfortable to drive.
I built the car myself to suit my needs at the time. It we designed to be used as a daily that I could take out to the track or to the skidpan on the weekends. It looks nice without getting attention from the wrong people. It is not overly loud
I am in 2 minds about selling the car but have decided as much as I love it, I have 3 motorbikes and 2 cars and would like to consolidate and have just the 1 car.
please check my garage below for photos
http://www.skylinesaustralia.com/forums/in...mage&id=580
http://www.skylinesaustralia.com/forums/in...mage&id=579
http://www.skylinesaustralia.com/forums/in...mage&id=578
ENGINE - RB30DET
I built this engine using an RB25DE head with less than 60,000 k’s and an RB30E bottom that has been rebuilt. All new gaskets and seals were used and VCT is disabled. The engine runs perfectly makes ridiculous power and torque.
Misc engine additions:
Holset HX35W Turbo
Turbomotion 40mm External Wastegate
Splitfire coilpacks
800cc Hiflow Injectors
Z32 AFM
K&N Pod
Turbotech Boost controller
Blitz Stealth same side return FMIC
Braided stainless lines for turbo and VCT
GTR fuel pump
3” turboback exhaust – Custom Frontpipe 3” Stainless catback
Suspension/Handling
Replaced front and rear struts
Kingsprings front and rear
Whiteline adjustable rear swaybar
Solid alloy cnc steering spacer
Adjustable forged castor rods
Driveline
Exedy 5 puck ceramic HD clutch
Rebuilt RB20 Gearbox with hardened shafts : 0
4.1:1 diff to give it longer legs and better traction!
Wheels/Tyres
RS-R 3 piece 17x 8.5 F – 215/45/17
RS-R 3 piece 17x 9.0 R – 255/40/17 Fedral RS-R Semi Slicks
Interior
BRIDE BRIX recliner
Ital Volanti steering wheel
Quick release wheel kit
GREDDY turbo timer
Autometer boost guage
Tinted windows – darkest legal
Dash lights changed to red for that Darth Vader look
Chrome gear knob and new leather gear / handbrake surrounds
Full 3 point immobilizer and premium alarm insurance approved
Stereo
Sony CD/MP3 headunit
Jaycar 6.5 splits
Eclipse 12” sub in custom fibreglass sub box
Soundstream Granite 4ch Amplifier
Boot retrimmed in standard grey carpet
I am not in a hurry nor do I need to sell it. I am looking for a trade for a Stagea or possibly a Legnum in good condition with minimal mods.
Or will sell the car for $14500
The car will be sold without rego due to the legalities of an RB30det :P
I am not interested in haggling and am not hard up for cash. I built it for a lot more than this and anyone that wound be genuinely interested would know what is involved in putting together a machine like this.
hey there old mate.i have a 96 stagea rs4.rego till march next year.gcg ball bearing turbo,hpi fmic,dump pipe to kakimoto exhaust.it is automatic and is a very nice car.it has 140,000kms.let me know if your interested.i will put some photos up if your keen.
^^^ your addicted!! :D
I remember when I picked up the old RB20DET off you for zeddles.... its definitely come along way!!
Took me ages to decide to sell mine.... and I am the same, if it doesn't sell Il just keep driving it around and enjoying it!!
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
