L20et And Dr30 Parts
Hey im bringing a container over from New Zealand a litte latter this year I have some L20et parts if anyone is interested?
I have
2 x complete but blowen engines (I cannot bring over the blocks as there just to heavy) so ask for bits and ill give you a price.
An ECU or 2, airflow meters, coupe parts, sedan parts I have a mint 4 dr DR30 in two tone grey over black. So great doors bootlid and glass
Basiclly ask and ill tell you if I have the part, what it will cost and weather it will fit in the box coming??
Also i Am Starting a small business importing Jap parts from New Zealand called NZJDM, so if you want a stock list of some of the bits and prices email me?!
[email protected]
Marc
NZJDM
L20et engines are so crap no-one in Australia would be interested at all....
Its the turbo sump/manifolds/management/ and associated parts that are in demand
dont waste your time with the head or block...
OI. What are you up to! post if you want some stuff, i dont give a rats arse if the l20et is worth nothing i only listed those things cause there sitting in the shed doing nothing the owe me nothing so i thought say i had them!
i have sumps Manifolds and computers for them + loads of other parts for DR and HR30 skylines ps im only bringing over R30 parts if people want them im not bring over stuff on maybes except for the front strutd as they are a good upgrade for RX7s
i also have
ITEM [/size]EVO 1-3 DIN GAUGES TEIN VR4 COILOVER (FRNTS) NISSAN R30 STRUTS x3 sets COROLLA AE82 SEATS JDM ZR4 FRONT GRILL SUBARU STRUT BRACE 1 SUBARU STRUT BRACE 2 COROLLA GT CENTRE CON BFMR BODY KIT + LIGHTS STI CARBON STRUT BRACE v1-v6 STI STRUT BRACE+under brace v7 RECARO SEATS- JDM GSR Lancer MOMO WHEEL RX7 VR4 THROTTLE BODY 2"
RACE SEAT-unbranded
Marc
Edited by FJ20DR30
that 4 door, does it have good interior?
hay mate sorry but it does not, it was a track car with a half cage welded into the back
its fairly stripped now
it has most mouldings, glass, subframes, pannels, brakes etc
Marc
Marc
Take it easy Marc
I'm sure his intention was to save you shipping costs for something of little value
Take it easy Marc
HMMMM you are correct i should take it easy sorry mag86, but i still think there is no need to add that to someones post.
As for shipping i have a calculater to work that out, i am not bring over anything that i dont think or know there is a dollar in, also if the original post was read correctly you would have seen that i will only bring over l20 bits if i have buyers for it
Marc
Ah so you're the guy I sent an email to yesterday. A friend of mine told me to contact you, I own a couple of DR30s and was wondering if you were willing to sell me a few items if you have them available.
I'm located in Auckland if that's any help.
Yeah i sent an email to you, what do you need man?
No negativity intedned, it was just a short post with no ramblings, straight to the point.
If you can find any LD28 cranks from the diesel patrols that would be a good investment on your part.
These should be getable how much are they worth here? plenty of Safari's patrol's and ld28 Laurels in nz
(Are the the 4.2 diesel ones the same?)
hey there,
Can you get a DR30 r200 longnose diff in a 4:11 or 4:3 ratio. If so how much?
cheers
sorry no diffs at present ill keep looking i can get nissan and subaru r200 lsds out of later stuff if there any use?
haha... my L20ET would still get up over your build at the moment.... They weren't designed to produce excessive power, it was more of a reliability thing for them i think considering mine still runs like new nearly 27 years after it was built and untouched internally.
may have a buyer for the r30 anyhow and the Chaser is flat out lushness to drive... shame i couldn't have the 1JZ in the 30
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
