Hey,
Wondered if anyone can help with this - I have an R33 GTST which is an awesome car, and it's been serviced regularly.
If I'm driving slow or accelerating slowly in the wet, the back wheels seem to lose traction and kick left/right and the back of the car fishtails. Don't know why. Tyres are new, I assume HICAS is working fine since it's been serviced and checked. It doesn't happen all the time, just occasionally.
Any ideas? Mechanics say it's normal. I've nearly ended up across lanes due to this problem so it's not hugely safe!
vekra
New tyres will always be slippery, it can take a while for their "waxiness" to wear off.
Alternatively what tyres are you running? nankangs or anything similarly crap will always be a awful in the wet.
Or bricks for rear shocks?
The only times I have issues is after a dry spell when the first rains hit...rain + a build up of oil on the road can be fun.
Thanks for the reply.
The tyres aren't brand new so I'm sure it's not a waxiness problem. Not sure what type - will need to check.
Not sure what 'bricks for rear shocks' involves! Is that something that may need repair, or something I can add to the car to make it safer?
I noticed this when I broke the HICAS unit off the rear subframe. I'd take it to a suspension place and get them to have a good look over all the rear bits and pieces.
Whats your alignment?
try 1mm toe in on the rear and minimal negative camber. that little bit of toe in i found to help my traction issues, along with raising the car, less bump steer means less toe changes through the suspensions stroke.
Cheers for all the replies... Some of them have been a bit too technical for me so I'm going to take the suggestions to my mechanic. Maybe they'll understand (taking it to RE Customs next week).
Not sure what alignment means... (wheels have been aligned recently though) :D
I have a thought... because basically the same thing happened to me- and I have a GTS4 ( 4wd- should be a great handler in the wet)
happend a few years ago ( back when i wouldn't have even known to change a flat tyre) I also did like 20 around roundabouts and the car almost spun out...
turns out the tyre pressures were like 8 psi over the max in all 4 tyres... was like driving 4 bricks on the road.... and it was because I didnt have a personal tyre gauage... cuz I just went by what the servo's machine was and they are all f*cked cuz ppl dropping them/missusing them.
I let some pressure out and she stuck perfect... now I keep it at a constant 4-5psi UNDER the max, seems to be best at that point.
So buy a $10 tyre gauage and use that to measure ur pressures and keep it in ur car....
Adam
Another thing is maybe check that the tires rotation are goin the right way been told that kids with low power cars do it to slide in the wet, the water sits in front of the tire rather then the tread releasing the water out the back havnt experienced this 1st hand so not sure if its true but you can always look
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
