While its good to get a person off here to have a look, I'd pay a workshop to check it out, say $200. Ask the dealer to get uniqueautosports or powerplay imports to inspect it, both are within 15 min.
if you have never been in a m35 before you can come check out mine if you want. im located in Balcatta WA
it isnt a axis, but still nice example with factory leather, might decided m35 aint for you after seeing one in flesh(assuming uve not been in one yet)
Excellent, good to find a m35 owner in perth, you must be able to count how many there are with your fingers cos I havent seen any in perth yet except for 1 at melville autos.
pm sent!
So i got the new job, i resign the old one tomorrow.
if you want, i can look at this car within the next 2 weeks! (except next monday)
Excellent Congratulations on the new job! :D
I've been reading some mixed reviews about this yard so want to be extra careful about this car.
I'll call up UAS or powerplay as well to check out the car. I wonder if the car is out of customs yet... I'll find out
Car has gone to compliance shop this morning, not sure which one though.
it will be in compliance for 10 days i rekon. maybe less. thats what i was quoted when mine was done (who knows what it really is)
anyway, PM me the dealer youre getting it from!
Hi there, Why not consider my car?
Im sure my car is much better condition to that one and Im also selling it cheaper then what is he asking for !
Here is some pics of my car!
http://www.skylinesaustralia.com/forums/Sa...Au-t284479.html
thankz!
thankz!
Hi Panda
PM me all the details
cheers!
Wil
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
