Okay,
Here’s my plan.
I want to make my car quick in a semi-unconventional way.
I don’t want to up the boost or do much work on the engine, I would prefer to make the engine more efficient to get the speed. Therefore keeping the look completely stock, the engine management completely stock and most probably stock boost.
I plan to go about this by lightening the rotational mass of all the bits I can. Flywheel, clutch, cam gears, pulleys, etc.
Has anybody taken this approach or had any results from these sorts of mods.
I plan to lighten the following…..
Flywheel and clutch combo
Camgears
Pulley sets on the front of the engine.
Remove clutch fan and replace with thermo.
Have I forgotten anything?
Am I wasting my time and money?
What sort of change would these mods make to a quarter mile??
Thanks in advance for any help…
BASS OUT
https://www.sau.com.au/forums/topic/28856-rotational-mass-mods/
I keep hearing this term "lightweight wheels", how light is light weight? The wheel manufacurers quote width, diameter and offset but trying to find the weight of their wheels is damn near impossible.
You weigh them!!
Stock mag 16x6.5" with 205 50 16 =19.25Kg
Modena 2 17x8.5" with 245 40 17 =20KG
" " 17x9.5" with 255 40 17 =21.5Kg
Weds sports racing C005
18x8 with 235 35 18 =18Kg
18x9 with 265 35 18 =19.5Kg
] You weigh them!!
So I have to buy them to find out what they weigh?
That is not much help when I am selecting which one to buy.
At least Speedy Wheels quote the weights of their lightweight wheels;
SIZE OFFSET STUD PATTERN WEIGHT
15x6.5 ET40 4x100 6.5kg
16x7.0 ET40 4x100 8.0kg
17x7.0 ET40 4x100 8.8kg
Very frustrating, I wish the other wheel manufacurers would wake up.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
