Excited About Oil
09GTR
 Share
I'm the sort of bloke who gets excited about power upgrades, turbos, intercoolers etc. But today I put the Willal tranny oil into my GTR and I was quite amazed by the difference this oil has made to the performance of my car. The low speed gear change seems so much smoother and there is no doubt that the box is quieter than before. Never thought I'd get excited about motor oil....
On another note I have now installed the Endless MX72 brake pads. Initial bite in cold conditions is noticeably better than stock, more pedal feel, no noise (so far). Will be wearing these pads (and Dunlops) at Drive Bathurst in November. Will give a report post this.
Glad you apprecitate our work :D
WR35TM is a labour of a lot of time, effort, and engineering....and we enjoy to hear results like yours as they happen. Good work to you and CRD for specifying the fluid :D
Thanks Martin, it really is impressive stuff.
had the Willall Transmission Fluid in my car for at least 5000kms and I love it. Also installed the big capacity sump and hammer the car all day long and the oil temp never goes over 100degrees.
Love the peace of mind good work Donger and the boys at Willall.
The Nissan recommended transmission lubrication schedule and materials are the achilles heel of the GTR
We worked from the outset of the world relase of the GTR to build a better mousetrap and come up with a longer life harder wearing fluid - that is WR35TM. The world market has adopted the product in droves, particularly in high performance or motorsport applications. The WR35TM resume on the front page of our website says it all :O
I have the WR35TM oil in my JDM GTR and attended a track day at QR a couple of days ago. We were running 15-20min sessions with about 40mins break between each session. The highest transmission oil temp I saw was 125 deg C. This may have triggered a TM oil replacement if I was using the factory fluid.
  • 7 months later...
We worked from the outset of the world relase of the GTR to build a better mousetrap and come up with a longer life harder wearing fluid - that is WR35TM. The world market has adopted the product in droves, particularly in high performance or motorsport applications. The WR35TM resume on the front page of our website says it all :blush:
so use make make your own oil or re badge someone else's oil?
Edited by BLACKFRIDAY
Ive had the Willall tranny oil for a couple of weeks now.. definitely quieter.
(btw Martin: I own the car that Dave from GT auto was talking to you about.. You were explaining how to disable VDC on my car when it was still engaging when switched "off".. Seems to be working properly now and off now means off, thanks)
Edited by druzilla32
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
