Hi All,
Just though I'd let you know that the new setup on the LeeWah GTR was completed on Friday night and the tuned on Saturday.
http://iceperformance.com.au/LeeWahGTRNOSRun.jpeg
We did end up at Heathcote on Sunday but due to some split IC silicone hosing, we didn't get many passes in. By the time the car was ready to run after replacing the hosing, it was 2 and the rain came in at bout 3 so we only got 4 runs in. The launches were all bad with a best 60' time of 1.87 on Nittos. Disgraceful I know :D The best run we had was a 10.7@138MPH which although the time was slower, the MPH picked up from the previous best which gives us some indication that the change was worthwhile. The best MPH of the day was 140MPH which I was pretty happy with.
Just a better launch and we should be seeing some good results. We'll be out again either on Friday night or on the 14th at Heathcote.
https://www.sau.com.au/forums/topic/28864-leewah-gtr-new-setup/
  • Replies 45
What is the new setup?
If you can give details of course Dave   :D
if not PM if you like.
Sounds good. Was there an increse in power after the new set-up?
The new setup was simply adding a NOS system to the car. We did use a 75hp shot which gave us an increase of about 80rwkw. It's actually closer to a 65rwkw increase as the last time we dynoed, we used "Ben" pesimistic settings and this time we used the standard "Ben" dyno settings which is supposedly a tad optimistic. We reckon on the pesimistic settings we would have made around the 505-510rwkw mark
Nice work on the dyno dave. Shame about the weather really! Did you get to run against Nigel? And if so please tell us you didnt get beat by a supra!
Nah, didn't get to run against Nige this time. His clutch began slipping after a couple runs so he packed it up so he could drive home. His best was a 11.5@135MPH so the tuning gave him an extra 5MPH which isn't too bad. The times, like mine sucked but the speeds are looking good if we can get the launches right.
Good to hear the nitrous has gone in
What brand of kit did you use? ZEX?? NOS??? Nitrous Express??
We had to stick with F&F style and use a NOS kit :D
I don't use buttons to activate the NOS though as I could have screwed that righteously. Instead, we use a full throttle switch which activates the NOS when the throttle bodies are at 100%, if not, there is no NOS flowing.
It truely is an experience driving a car which spools this hard and this fast!!
"Only 10.7@138MPH" said the good dentist...
good job on the upgrade, just outta curiosity atm u'r pushin 710hp, any plans on breakin the 1000hp barrier?
Where did you get 710hp from?
526.3kw = 685hp. Using the "accepted" drivetrain loss of 30%, my engine would have somewhere around the 890hp mark.
There are no real solid plans for what happens next to the car. If the idea at the time sounds good, we give it a go :D
I think he got the Beemer as well... think he wanted an M3 or sumfin its not that bad... if he keeps this up he'll have his own private jet soon to take down the drag strip.
as for 710hp I dunno i got a conversion rate 1kw = 1.341022hp, so naturally 530kw = 710.7417hp = 125816.5 calories/second = 388179 pound-feet/sec
wow, i can't even begin to imagine driving a car that fast (i have a whole whopping 56kw's @ fly to play with :D)
from that graph, and what very little i know about them, looks like it's pretty streetable?? looks to be a fairly linear cept for the top bit. What it's like just to drive around day to day? it's it a daily driver?
M3 hey.... nice choice :) dorifto....
cheers.
oh and is the 30% loss thru drive-train applicable to all cars??
No I don't own the BMW aswell. My brother owns the 330ci convertible which I borrowed for a couple weeks.
It's amasing how much .04 makes when you're referring to 526 kw...
I stand corrected.
The car is still driven on the street when stuff isn't being plugged in. No funny gas plugged in though. Even without the gas, I can still make around 450+ rwkw so it's enough to get from A to B.
The thought of an E46 M3 has been in my mind for sometime now and only time will tell whether it will become a reality.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
