M35 Turbo Noise
wailiam
 Share
Hi Guys
I just drove a M35 bog standard with the stereo turned off. The engine is pretty smooth but upon acceleration you can hear a whine\whistle that goes with the RPM of the turbo. Being a standard car i'm not sure if this is normal. Do any of you know? I have previously owned a Skyline with RB25DET in it and you couldnt hear the turbo at all.
It kinda puts me off wanting an M35. Reminds me of a bad stereo install where u can hear whining noises from the speakers.
cheers
Wil
Hi Guys
cheers
Wil
I think you will find the turbos rear bearing is on the way out and it will probably need a rebuild soon.
They are a little noisier than the average turbo car due to the placement, right in front of the passengers feet.
I think it didnt sound unhealthy. Seems like most M35's have this noise. I'll have to learn to live with it, just turn up the stereo. I'm turning into an old man, dont like loud exhausts, air filters, BOV anymore. These days I like it when the engine and exhaust are quieter I feel like its got effortless power so when I overtake someone they are like "woah where did that come from"...
The snail in a stock C34 is audible, more so with a SS dump (less insulating than the OEM cast/mild dump).
Without actually hearing it, I wouldn't say that it was good or bad. Some cars are quite noisy, others are quiet. The FJ20 has a real whistle, whereas the RB25 is more like a gentle 'howling' noise. They'll all get mighty noisy if the turbine intake gasket is buggered - been there and tried to drive avoiding boost because of the deafening shrieking it made.
:O
Short answer: YES it is normal.
The C34 turbo is audible, though fairly faint and generally more noticeable at lower revs as you just come onto boost.
In the M35, its the same sound - like a faint (ie. not harsh) whistle but much louder than the C34. I put this down to better airflow through the VQ25 plus the fact the M35 runs fairly high boost from the factory compared to the C34.
My prev s2 had a cracked exhaust manifold and the turbo was starting to go when I bought it and that made the turbo quite loud but a very different sound. If its not a harsh metallic sound then you should be fine.
My M35 has now done 25000+km since I bought it and the turbo's still going strong.
Yeah my wifes car does the same she dosent notice it that much as she is playing kids dvds most of the time.
Hey pixel8r I think you live close to me we should compare our cars one day.
Yours is the white one yeah? I see it every now and then :)
ducati02 and pixel8r - Where are you guys in Adelaide?
I'm just north of the city (Grand Junction Rd) - I've only ever seen 3 other M35s around...a white one, a blue one and a silver ARX.
Hi im at gulfview hts im the white one and pixel8r is the blue I think. It would be good to check out another m35 in the area one day
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
