hey guys just bought a 32 skyline
i new the problem was there and it is this
when u go foot flat to floor or more then 3/4 after about 4k revs itll start missfiring/popin as such my guess was new coil packs wood solve that problem as it is a stock car with a FMIC on it and a pod but before 4k revs and if ur not ful throttle it doesnt do it and it idles fine please help :O
https://www.sau.com.au/forums/topic/288678-rb20-missfire/
Plugs or coilpacks. Pretty common with RB's, or the old fuel pump is getting tired. Replace your plugs first, then look at the coilpacks & fuel pump. I've got a spare set of RB pack's if you get stuck dude.
https://www.sau.com.au/forums/topic/288678-rb20-missfire/#findComment-4835640
Pretty much plugs or coil packs. If it doesnt have an aftermarket pump, check that as well. Otherwise, it could intercooler piping, I've just fixed that problem in my car. Check them all in that order, because new plugs would be beneficial whether they are causing the problem or not.
https://www.sau.com.au/forums/topic/288678-rb20-missfire/#findComment-4835660
man i've had 2 missfire issues with my rb20 over the last couple years... whenever you mention a missfire on here you get a million people saying coilpacks.... and while it is a somewhat common problem with skylines, it was never the solution for me and it's not necessarily the solution for you.
my guess would be your crank angle sensor.. sounds very similar to when mine had problems..
but it's just that, a guess... could be a variety of things... best bet is take it to a garage that knows skylines and get them to tell you what the problem is.. will cost about 100 tops to find out what it is.. which is cheaper than trying 5 different things to fix it.
https://www.sau.com.au/forums/topic/288678-rb20-missfire/#findComment-4835812
when u go foot flat to floor or more then 3/4 after about 4k revs itll start missfiring/popin as such my guess was new coil packs wood solve that problem as it is a stock car with a FMIC on it and a pod but before 4k revs and if ur not ful throttle it doesnt do it and it idles fine please help :P
hi probability its the tune mine does it at 6k but it has been tuned /de-tuned so id check your tuning
https://www.sau.com.au/forums/topic/288678-rb20-missfire/#findComment-4852590
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
