Hey guys, Im from the US. I have an S13 with an RB20det installed.
Heres what Im workin with...
Rb20det
Precision SC61 turbo
Z32 MAF
750cc RC injectors
Nismo bypass to Aeromotive FPR
Walbro 255
ROM tune with Ostrich and Carl H's assistance
Consult
Innovative wideband
Here's my prob.....
I run VERY rich at idle and at cruising speeds. Under load and boost the motor performs great.
I run so rich, my WBO2 reads "9.8".
Everything Ive checked, checks out fine. When I hook up the consult, everything "seems" too be running and checking out to spec.
MAF .50 key "on"
TPS .44
????O2.......which is reading .95 lambda = 14.0 AFR???
ECT within spec
Fuel Pump within spec
Timing 15*
Ive checked voltage and ohms on everything I can think of and its all fine and Ive changed the plugs 4 times now.
On Carl H's end, everything checks out to what its suppose to be with the ECU, according to him.
I'm at a loss guys, does anyone have any ideas on what else too check that would be causing these probs?
The weirdest thing I see the stock O2 sensors readings. Its not reading what the WBO2 is..not even close.
https://www.sau.com.au/forums/topic/288719-rb20det-running-terribly-rich/
the stock o2 sensor isn't a wideband sensor. it is only designed to read between 14 and 15:1 and send the ecu a signal of either lean or rich. anything leaner than 15:1 it says rich, anything richer than 14:1 is says rich and in between is stoich. they ecu doesn't actually monitor the exact AFR.
it may possibly be that the stock o2 sensor is dead and that is why you are getting shocking economy, or the closed loop tune may be innacurate, or not even activating, however then it should just run on the same map as wide open throttle. i would be leaning more towards the tune than the o2 sensor.
I agree, today I did some test and came too the conclusion that the O2 sensor is fine.
I did find some, what seems too me, odd findings during my search today.
Let me ask in the form of a question lol
If I would check for continuity between the 2 pins of an injectors pigtail, should I get continuity?
I also put one side of the ohm meter in one side of the injector pigtail and check down at the ECU and I had continuity from the #6 pigtail to all the injector signal wires at the ECU.
I then put the one side of the ohm meter on the other pin of the same pigtail and did the same test and got continuity on all the same wires.
......does this sound right?
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
