Nissan R34 Gtr V- Spec
sly14
 Share
hey guys i have decide to go ahead and sell my gtr after been very half hearted about it if it sells it will be good if not im happy to kep the car and keep building it up.
The car was imported by zele imports which are known for there high grade gtrs that they stock and shows in the flesh.
so specs are.
1999 v spec
70xxx kms
just serviced
immaculate bay side blue
original gtr floor mats front and rear
original hid's
alarm system
zeal coil overs
garret 2560-5 turbos brand new and installed a few weeks ago with all new gaskets, fluids etc. with recipes
new blitz front pipe
new blitz de cat pipe
new nismo weldina exhaust
nismo front indicators
nismo side indicators
color coded front lipe
tv/dvd player
bridgestone 265 re01's
im sure there is more that i have left out.
i have pictures of the hole car from when i purchased it boot,body, panels, engine bay, etc etc so if your after more pictures let me know. this car is immaculate throught and a perfect base for some one that is after a as new gtr.all inspections are welcome.
also i should mention the car was imported stock standard and all modifications were done in the last few months all brand new.
$51500
PLEASE NO TIME WASTERS.
PH: 0423697701
kind regards :O
Edited by sly14
if your genuinely interested in buying my gtr send me a pm with your email and i can send a few through.
cheers
if ppl are genuinely interested please call me and come have a look instead of pming me as i dont have enough time or access to keep checking back here.
cheers guys
Reading your above two replies to my posts, its like from the start you didnt think i was genuinely interested. Im not sure why?
Anyway, if i was located in adelaide i would have made an appointment to just come over to look at your car in person. If you've seen my posts around the forums - you'd see that your car was almost exactly what i have been searching for, and it was in my price range with no negotiation necessary.
Im in sydney and willing to travel ASAP if necessary for a GTR just like this, however for the interim (or atleast until this weekend) - additional pics were the only way i could get a better view on what i was potentially purchasing. I didnt think it was that big of a deal, as you said in your first post 'if your after more pictures let me know'. If i wasnt 'genuinely interested' in buying - i wouldnt have even been asking!
I appreciate your time anyway, sorry for any inconvenience.
Cheers and good luck with the sale.
Edited by KR4-GTR
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
