they have to get you to sign a release form... public space or not, if you can be identified they need a signed release
Never sign a release without asking for payment;)
LOL, is that a hint that you might make an appearance on this show?
  • Replies 279
lol no... just in general if anyone approaches you in the street to use you in a show or commercial or something you should NEVER sign the release until you have asked for payment... unless its a charity or something people are making money by using your image and you should be paid for it... they will try and get you to do it for free just 'to be on tv' but that's rubbish
once they have your footage and you have signed the release they may (depending on the terms of the release) use it however they want... chop it up, take you out of context, sell it on etc etc... so make sure you read it before you sign it!
so what about the dodgy fridge mechanics and feuding neighbours on a current affair and today tonight, im sure they didnt sign a release as they ran off covering there face.
What about asking them to not fine you, then you will sign the release form? lol
But it will be funny seeing who will be the first from SAU to be on the show haha.
Can't wait!!
pretty boring..skipping back and forth between a couple of stories.
i thought the woman police officer dry reaching in that guys car in fawkner was pretty funny...
lol at the preview..
ive always wondered what cops would say if you were busting for the loo..
It was quite disappointing :)
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
