Hi
Need to size a turbo and injectors for my RB25 R33
i want to use it for drifting so it should be responsive
car already has :
- Hybrid FMI
- Full 3" zorst
- splitfire coils
- pod and CAI
- tomei fuel pump
- nismo FPR
- HKS EVC5 boost controller
have just brought a Power FC and am going to get this fitted along with Z32, new turbo and injectors.
would like to keep standard turbo manifold and use the 3" dump pipe already fitted
would like about 350hp @ wheels or more
have budgeted about $1000 for injectors and $1000 secondhand to $2000 new for the turbo
so my questions are:
- What turbo
- what injectors
- also can i keep the cold start function with a Power FC
  • Replies 44
if you want to keep the dump you have with the standard turbo then your best bet is a highflow, which should also be sufficient for your 350hp goal.
injectors, different people have different opinions but i'm using nismo 555s and they're great
and yes power fc's have cold start functions
i thought alot of aftermarket turbo fit in place of the standard one without changing anything
for $1800 we can make you a Garrett GT3071R BB CHRA in a .63 Bolton housing in .60 A/R Comp with 14psi internal gated actuator. that would be pretty responsive for your power goal with good torque.
GCG highflow, Nismo 740cc injectors to give you breathing room for future upgrades(same price as the 555cc), 480cc SR20 injectors are the budget option.
a GT3071 or 76 kit is ~3k
Sounds like a good option, but have heard many times of the potential boost control issues with these combos, do your setups have this issue?
some of the hks ones do but they cost a small fortune
all the others i can think of are a highflow of some sort
if you want 350hp u may run into boost control issues as said above, when running the stock manifold, your going to have decide as to how serious you want to be about your up grade, do you either get the bolt on and run into a wall when ur after more, or spend the extra couple of grand and go external gate, 6boost manifold, and a decent garret turbo. why not get some cams and timing gears as well.....etc
its a pretty hard choice and decent investment what ever you decide on think about what your going to do with the car spend the extra now and save the head ache latter
Nope. Depends on how your engineer the internal wastegate port and size of the wastegating flap. We've done quite a few. No problem with boost creeping at all.
am not gonna have the extra money external gate and cams
I see heaps of people with 350rwhp using the standard manifold and think i should be able to do it
hks2835...shits on standard boost response...no response...full boost and 250rkw at 19psi at 3200rpm...drift that bitch!
how does this turbo compare to the Garrett GT3071R BB mentioned by hypergear
i also believe a gt30 is the way to go.
even better if you spend an extra 1k for a rb30....youll make the turbo kick in earlier, with less boost and more power.
hopefully your not running a rb20....
engine is an RB25 and don't think ill be putting in an RB30
just looking for a new turbo
Any 450hp core (or close enough will do what you want, each with its pro's and con's.
So GT3071, HKS GT-RS, HKS 2835ProS, GCG hiflow or Hypergear's recommendation.
You seem to want a low cost direct bolt on option so something from Hypergear or GCG will meet the target and for the lowest cost.
550cc injectors will do the job.
i'd go a second hand HKS GTRS if i were looking for something that bolts up....
slightly more responsive than a highflow and very bolt on..... 2835 is a better turbo for a 25 but more $$$ and needs a custom dump.
is that all you ended up with? i thought you sorted all that out
mine makes 285 @ 19 psi
thanks for everyones answers
think im gonna go the Garrett GT3071R BB recommended by hypergear along with sard injectors
can i keep the cold start function ?
You'll need additional collars for the sard injectors whereas Nismo don't for similar price new.
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
