After searching on here for threads about installing a FMIC and finding mixed results I decided to buy a kit and give it a crack for myself. The kit I bought was a Blitz CS return flow type cooler which came with everything I needed - cooler, pipes, clamps, brackets and bolts.
Anyway so here we go
Remove the bumper, there is already a guide for which which I followed and worked great so no point explaining this
Remove/undo the brackets of the air filter or remove the airbox, just do enough to get to the clamps on the cooler piping
Remove the SMIC by undoing the 4 large bolts and 2 smaller ones on the vertical bracket
If you're as unlucky as I was you'll discover at some point your car has blown a turbo and the remanents of it are inside the intercooler :)
Remove the vertical bracket that was holding the stock cooler on
Remove the top reo cross bar and undo the bolts securing the side reo to the main bar and remove the side reo bits under the headlights
Remove the main reo - there is a bolt and a nut on each side, its only necessary to fully undo the front bolt because the rear one is a slide type so just loosen it enough.
Fit the cooler using the brackets given in the kit
At this point I had removed the horns as well, but later I was able to fit the back in behind the cooler
U can see on this side there are a couple of hoses putting pressure on the cooler, I didn't worry about this and just left it.
I got the cooler in the position I wanted and then did a test fit of the reo (first of many!), I found that I needed to get it UP as far as possible on the brackets or the bottom pipe of the cooler would be too low to get the plastic underbody shit to line up with the bumper.
Cut the reo!
I had to bash out the mounting brackets for the top reo bar as well, basically just removed the lip from it so the tops of the cooler tanks would slide in right underneath.
I ended up cutting from the middle crossbar straight across to the edges.
U can see here how a section is cut out (action shot!) actually had to take out a bit more than this but you get the idea. Just cut a bit and do a test fit and repeat about 100 times until it's just right. Then smooth it out and hit with a bit of black spray paint.
And done! the reo now fits back on!
Next is cutting the bumper, quite alot needed to come off here, this is it before
and this is it after
on the left here the whole shroud was removed so the pipe would go on, being careful not to mess up the mounting for the driving light. The middle bit basically got munted right back so that it sat flush against the cooler
If you've done it correctly some parts previously on your car are now on the garage floor
And done!
At first I was a bit hesitant to do this to my car because of the cutting involved, but overall I'm very happy with the result, the cuts in the reo are only really visible if the bumper is removed and even then you gotta know what you're looking for. Although anyone who is looking for cut reo WILL be able to tell no matter how good the job is.
I'd definately recommend this kit, the parts are good quality and no messing around getting it fit, the brackets were spot on and it makes good use of the available space to fit a decent size core in there.
It took about a day and a half to do ... gotta say though I'm pretty happy with the result :down::mad::(
  • Like 1
https://www.sau.com.au/forums/topic/288799-installing-return-flow-fmic/
Black Holes
What is a black hole? Well, it's difficult to answer this question, since the terms we would normally use to describe a scientific phenomenon are inadequate here. Astronomers and scientists think that a black hole is a region of space (not a thing) into which matter has fallen and from which nothing can escape - not even light. So we can't see a black hole. A black hole exerts a strong gravitational pull and yet it has no matter. It is only space - or so we think. How can this happen? (wow gold)
The theory is that some stars explode when their density increases to a particular point; they collapse and sometimes a supernova occurs. From earth, a supernova looks like a very bright light in the sky which shines even in the daytime. Supernovae were reported by astronomers in the seventeenth and eighteenth centuries. Some people think that the Star of Bethlehem could have been a supernova. The collapse of a star may produce a White Dwarf or neutron star - a star, whose matter is so dense that it continually shrinks by the force of its own gravity. But if the star is very large (much bigger than our sun) this process of shrinking may be so intense that a black hole results. Imagine the earth reduced to the size of a marble,but still having the same mass and a stronger gravitational pull, and you have some idea of the force of a black hole. Any matter near the black hole is sucked in. It is impossible to say what happens inside a black hole. Scientists have called the boundary area around the hole the "event horizon." We know nothing about events which happen once objects pass this boundary. But in theory, matter must behave very differently inside the hole.wow gold
For example, if a man fell into a black hole, he would think that he reached the center of it very quickly. However an observer at the event horizon would think that the man never reached the center at all. Our space and time laws don't seem to apply to objects in the area of a black hole. Einstein's relativity theory is the only one which can explain such phenomena. Einstein claimed that matter and energy are interchangeable, so that there is no "absolute" time and space. There are no constants at all, and measurements of time and space depend on the position of the observer. They are relative. We do not yet fully understand the implications of the relativity theory; but it is interesting that Einstein's theory provided a basis for the idea of black holes before World of warcraft Power Leveling,astronomers started to find some evidence for their existence. It is only recently that astronomers have begun specific research into black hole. In august 1977, a satellite was launched to gather data about the 10 million black holes which are thought to be in the Milky Way. And astronomers are planning a new observatory to study the individual exploding stars believed to be black holes.
The most convincing evidence of black holes comes from research into binary star systems. Binary stars, as their name suggests, are twin stars whose position in space affects each other. In some binary systems, cd keys,astronomers have shown that there is an invisible companion star, a "partner" to the one which we can see in the sky. Matter from the one which we can see is being pulled towards the companion star. Could this invisible star, which exerts such a great force, be a black hole? Astronomers have evidence of a few other stars too, which might have black holes as companions.
The story of black holes is just beginning. Speculations about them are endless. There might be a massive black hole at the center of our galaxy swallowing up stars at a very rapid rate. Mankind may one day meet this fate. On the other hand, scientists have suggested that very advanced technology could one day make use of the energy of black holes for mankind. These speculations sound like science fiction. But the theory of black holes in space is accepted by many serious scientists and astronomers. They show us a world which operates in a totally different way from our own and they question our most basic experience of space and time. Runes of Magic gold
Black Holes
That bit made me laugh cause i played wow..
Thanks for the tutorial, about to undertake this on the brothers S15 in the next few weeks..
  • 7 months later...
If you're as unlucky as I was you'll discover at some point your car has blown a turbo and the remanents of it are inside the intercooler :blink:
Cut the reo!
And done!
It took about a day and a half to do ... gotta say though I'm pretty happy with the result :down::(:rofl:
i have also fitted one of these... quite simple... just need the tools
  • 6 months later...
Thanks heaps Realor for this DIY, great work!!
I just installed a FMIC on my car using these instructions and documented the process here:
R34 Gtt Front Mount Intercooler Installation - Some tips for a Trust vertical/turnflow kit
Anyone looking for how the get the front bar off there's a good DIY here:
Taking Off Gtt R34 Front Bumper - With Pictures
Cheers
Edited by V28VX37
  • Like 1
  • 11 months later...
Excuse the thread bump - but nice guide.
I am currently installing a cooling pro stealth return flow intercooler at the moment. Got it all plumbed up fine - just have to cut the reinforcing bar and trim the front bar, then reinstall them both.
It is worth noting that with this intercooler on an R34, if you bolt the centre mount to the front of the car, neither of the two side mounting points line up with anything, no matter how you position the supplied brackets. They come close but still won't work without modification.
Edited by R34mac
thanks for the guide made my install easy as .. i used a jigsaw with a metal cutting blade to cut the front reo took me 3 cuts to get it right and a neat cut too
ive got a r34 nismo front kit and this didnt require cutting for the intercooler
  • 1 month later...
I have that bar as well and didnt have to cut it either. I also only had to cut one side of the reo to get it back on. There was just a bit of messing around getting the return pipe and cooler up high enough so the undertray would bolt back up. No problems though and its lowered about 2 inches :D
there was a bolt i didnt need in the kit coz for some reason it was to far to be bolted to the hole in the shasy lol.. didnt have a problem with the return pipe tho fit quite well above the gravel tray ... recently put a oil cooler n which is on the drivers side before the window washer bottle.. that sits on the grave tray hope it doesnt crack if i hit a bump
  • 1 month later...
  • 9 months later...
Apologies to bring this thread back up to rave from the grave.
Just installed a JustJap Return Flow Stealth FMIC kit on my S2 R33 gtst. If people are looking into getting this kit for their R33, be prepared to trim of quite a fair amount of the front bar, as well as the back of the passenger side fog lamp housing.
The hot pipe bend that feeds into the core sits right behind the fog map housing, which mean you need to take away a fair bit of it away before the bend sits flush.
Also another trick is to combine the two L brackets that comes with the kit into one joining piece. Then you can use this one piece to fix the core on the driver's side onto the bottom of the chassis, right under the aircon core.
  • 4 weeks later...
I tryed to install a blitz return flow kit on my r34 last night but could not get the piping to plum up.
I got the cooler into position with brackets and all and reo back on but could not get the pipes back into place do I use all the stock hoses ? And just drop the stock intercooler ?
Also the bottom intercooler pipe is 2 inch and the intercooler out let is 2 1/2 inch. Is this how every kit is ? And they had to use a reducer to fit the pipe to the cooler ? (Which my kit did not come with)
Ps I bought it from eBay from jdm plant
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
