Hi guys,
I have a black 1998 r34 GTT, 2 door (coupe), manual for sale. Geelong VIC.
$4,700 OR BEST OFFER, offers via PM please.
car had about 120,000 kms on the clock, genuine kms i have the papers from japan, it has had its 100k service done, and serviced every 5000km since then, and i have a manual with it.
Car had an accident and the front left (about where the stock side mount intercooler would sit) hit a tree unfortunatly :)
i want to sell it as a whole otherwise i will part it up i guess.. airbags did not deploy.
Car does run. Never had any problems with it
feel free to call or text msg me on 0408340465 (if i dont answer just leave a msg) pm on here or email me [email protected] and i will get back to u ASAP
i seem to be only able to send a couple pms a day though.. so phone call, text or email might be easeir for me to reply to questions than pms. if you pm leave a mobile or email so mayb i could contact you.
its a repairable write off. can supply vin numbers all that sorta stuff.
only mods were turbo back exhaust, pod and FMIC which were all done by me within the last year.
will post pics soon...
Thanks :down:
yeah, i cant PM yet, because my post count isnt high enough.
pretty keen for it, check my topics to have a looksie at what has been done to it.
Pm me or message me if interested and we can discuss further.
cheers.
Hi, would definately be interested. When would you be putting pics up?
Does it run well? or is it not the way it was before the accident (just wondering if damage is mostly aesthetic or mechanical). thanks
hey driftn, i didnt have it running for long as i was just seeing if it started really... wasnt gona drive it or anything so didnt leave it run for more than say 15 seconds but it seems fine, the damage is basically all cosmetic apart froim the intercooler piping i dont think is any good coz it was at the front but apart from that engine gearbox everything seems fine. the panels all around the car arnt great n have some dint n scratches but interior and engine seems fine. msg me 2morro i will b at work but i would b able to mms ya some pics, otherwise i should b able to email em to ya soon... but at least mms will giv ya an idea... thanks
pics of the car, u can see where i hit the tree with the front left and the car spun off it on grass. hope this helps guys, i get the car delivered home at 1pm 2morro. can any1 tell me how to edit my headin of topics =S thanks
dude r u sure that is repairable ? looks like the chasis has twisted :S
Yep it is mate. I was at the insurance company with him. Photo actually looks worse than in person. lol.
If i had the cash i would by this..
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
