I have just fitted R34 V Spec Brembo calipers front and rear to my R32 GTR. The front calipers fitted with the V Spec 324mm rotors I have, but with the rear calipers, the rotor used (V Spec 300mm) are too small ie the brake pads are only half on the rotor. There is space in the caliper for a much larger diameter rotor. On searching the web I have found many comments that the Aug 2000 onwards R34 V spec used bigger rotors. Only on one entry though did they state the size - 322mm.
Can anyone confirm the 322mm rotor as a fact, and where I can get some from. The DBA catalogue only lists a maximum 300mm rear rotor for the Brembos.
thanks Mike
thanks Mike
322mm rotor is a fact. Sorry don't know where you could find some other than Japan.
Thanks. Yes I have now ascertained the following for anyone else who is interested:
- The R34 Aug 2000 onwards GTR V Spec & Nur models, rear Brembo caliper and rotor is 322mm in size
- The OE 322mm rear rotor from Nissan is $1100 each!
- Brembo 322mm rotors are available for $400 the pair
- DBA do a 322mm rear rotor for the 350Z (DBA 4601) which is almost identical to the specs of the Skyline 322mm rotor, only difference being 0.5mm difference in original height - Skyline (63mm ht) and 350Z (62.5mm ht) $510 the pair
  • 1 year later...
where can i buy the brembo 322mm rotors from $400 seems a bargain - i need to replace mine
GSL RallySport - 1300 884 836, or PM me.
Brembo Std $238 for the pair
RDA Std $238 for the pair
RDA Slotted $309 for the pair
DBA 4000 Series Std $330 for the pair
DBA 4000 Series Slotted $490 for the pair
Project Mu CRD Slotted $519 for the pair
Project Mu SCR Slotted $875 for the pair
Brembo are in stock, RDA and DBA should be in stock, Project Mu you might need to allow a few weeks to order in.
Regards,
Greg
Correct! To the point where most manufacturers just round it up to 63mm in both cases:
As discussed -
According to Project Mu there is clearly 1.5mm difference between hat sizes on the z33 rear and the r34 gtr 322mm rear rotors.
Like i said to you im not interested in buying something that will work, I want the one that was designed for my car and will centre correctly in the caliper
Project mu website
Thanks
Jason
I just bought mine through the local brake place (Southwest Brakes Bunbury WA) in this case. They were in Brembo boxes.
Have worked fine
regards
Mike
As discussed -
Thanks
Jason
Project mu have a proper rotor in your size. Hatted, slotted, everything. Get those. For some unaccountable reason they dont make them in the right size for rears on the rest of the GTR range.
Descrizione
The PROJECT MU SCR-PRO Rotors - Rear Nissan Skyline GT-R BNR34 are designed specifically for high horsepower output vehicles. SCR-PRO rotors are constructed as a two-piece rotor design. SCR-PRO rotors are developed from super tough FC Cast Iron Material and are heat-treated for reliability, durability and thermal stability under aggressive driving. The affixed bell housing is made from a billet aluminum alloy for strength as well as reduction of unsprung weight. Project Mu SCR-PRO rotors are available as front and rear replacements including vehicles with the factory Brembo calipers. They are manufactured from the factory featuring a slotted and dimpled surface to facilitate better pad wear and maximize cooling and braking performance. SCR-PRO rotors also feature a specially designed internal vane to improve heat dissipation from the rotors.
Product Specs
Brand: PROJECT MU
Product: SCR-PRO Rotors - Rear Nissan Skyline GT-R BNR34
Part Num: GPRN012
FEATURES:
- Compatible for Vehicle inspection
- Special Heat Treatment
- Compatible with Circuit Use
- 8 Straight Slits
- Black Painting
- 2 Piece Structure
SPECIFICATIONS:
Application: Rear Brakes
Structure: 2 Pieces
Slits: Straight/Eight slits per side; sixteen on both sides
Materials:
- Disc: High-alloy high-carbon FC cast iron
- Bell Housing: Aluminum alloy
Dimensions (mm):
- O-D: 322
- Thickness: 22
- P.C.D.: 114.3
- Holes: 5
- Height: +2.2
- C.Bore: 68
PRODUCT NOTES:
- Project Mu Bell Housing are 2.0mm wider compare to Stock OEM. When mounted the wheels will have a 2.0mm offset.
COMPATIBILITY NOTES:
- BNR34 N1: Only vehicles before 8/00
- BNR34 Standard: Only vehicles after 8/00
Compatibility Info
Nissan Skyline GT-R BNR34 (Zenki - 1/99-8/00) Eng: RB26DETT
Nissan Skyline GT-R BNR34 (Chuki - 8/00-10/00) Eng: RB26DETT
Nissan Skyline GT-R BNR34 (Kouki - 10/00-8/02) Eng: RB26DETT
Having said all that I am not sure how they cope with wear from the handbrake. Some other types have a steel liner on the hat for that very reason.
Edited by djr81
The mounting face on the Project Mu Skyline rear rotors (both 300mm and 322mm) is 1mm thicker than it is on the Project Mu 350Z rear rotors, and so to compensate for this, the Project Mu rear rotors are made to 64mm to centralise. If you don't beleive me, have a look at SCRN008 (300mm rear), which is also 64mm according to Project Mu, but is 63mm according to both RDA and DBA, and indeed most other manufacturers. The manufacturers overall height will vary a mm or two in some cases due to their preferred thickness of the mounting face part of the rotor, in order to keep it in the middle of the caliper. The actual, real world, bolt-it-to-the-car-and-measure-the-difference-at-the-caliper is only 0.5mm...
They do, they make CRD and SCR to suit 300mm rear, but only 322mm rear gets the two piece SCR Pro.
Actually the 2mm thicker alloy hat on the front caught me out. I put them on then wondered where all my thread depth on the wheel studs went.
Yeah I have the SCR's on the rear of my car. They weigh a tonne & have more vanes the the SCR Pro's. NFI why they would do that. But they haven't cracked.
yeah I wish they made the SCR pro 2 piece in regular GTR brembo size for the rear as well. they are good rotors. other option is a biot kit which comes with bigger rotor, and new caliper mount bracket to space the caliper. they are a nice 3 piece rear rotor (rotor, hat, and inner bell for the handbrake). a bit on the $$$ side though.
  • 8 years later...
300mm solid rotor for non V-spec from my experience.
If you need help with DBA parts I can help source them for a good price, the part is DBA4929 or DBA4929S for slotted or DBA4929XS for Slotted & Drilled.
According to my list (which I have copied from a website and cannot verify as being 100%)
The R32 GTR had 296mm rotors with Sumitomo calipers
The R32 GTR V Spec had 324mm with Brembos
but the  R33 and R34 GTRs had 324mm with Brembos on both base and V spec models.
You're referencing front rotors :)
@adey was after the rears which comes in 3x different diameters
Oops you are right - my list doesn't mention rears ?
Thanks guys!
FWIW I've found 2 references on yahoo japan auctions of rear BNR34 discs -- not specified as V-spec discs -- that were 322mm in diameter.  That doesn't mean that the sellers didn't "forget" to include the word vspec, but it's 2 data points.
But, I'm pretty sure both the 300 and 322 rears were both vented rears...  the R32's 296s were probably vented, too...
So, the search continues...
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
