Late R34 V Spec Rear Calipers/rotor Size -?322mm
I saw some online elsewhere: https://www.transmissionpartsusa.com/product_p/67393c.htm?gQT=2 No idea if it's real, how trustworthy they are, etc. -
By Mmcmasters · Posted
Frist drift car build, got a great deal that I couldn't pass up but going into alot of unknowns and first any info is welcomed. Will be posting what I find out from taking apart the swap someone else did to figure out if they did it right and if not how to fix the problems I come across. Location Buffalo NY USA. -
Fire up the 3D printer and break out the silver paint.
That'd be right ~ the early RE5R01A is pretty much the same as the RE4R01A in many ways ; problem is they made lots more 4-speeds than 5-speeds.... I'm in AU, so you'll need apply the US supply scene... https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/Mazda/RE5R01A/#scroll-electrical_components This'll give you the aftermarket parts listings -- you're looking for #56712 & #56713
