I've been noticing over the past week or two that my Stagea has had slight rev issues but they
werent really causing any problems. However just over this weekend on two occasions the car
stalled. Both of these times i was stationary and turning the wheel, so when i got hope i tried it
in the driveway, and turned the steering wheel and it stalled. It doesnt seem to make a difference
whether the car is hot or cold. I have a 99 Stagea RS Four S.
https://www.sau.com.au/forums/topic/288839-s2-stalling-issues/
will it do it with the aircon on too?
might be ICV (or whatever its called on an RB) or your throttle body could be a little choked up with oil and needs cleaning.... also clean AFM while youre doing that!
try it with the aircon on, the idle control valve will open (or close - i can never remember which) depending on load at idle when you switch stuff on, like aircon, or turn the wheel and the pump loads up.
also, check your spark plugs seeing as the bonnet is up and the throttle body is off :)
is it hunting a bit at idle?
another quick cheap thing to check there could be a simple vacuum leak from one of the many small vacuum hoses. the small one at the front of the plenum is a classic for a small split but it is worth checking them all.
My RSfourS has both Boost & vacuum to p/s load switch above power-steer pump, 1x straight boost off t-piece near std boost controller, 1x manifold vacuum and goes to never-never!
Have you disconnected battery recently?
IAC idle valve does gunk up over time but ecu compensates, If you've reset ecu then it goes back to factory settings with gunked up IAC valve.
Sometimes takes weeks of normal driving to sort out or quick 5 min ecu-reset/idle-reset procedure, even power fc manual stats it!
disconnect batt - start to operating temp, idle no loads at all, one at a time - low beam then high, a/c on, steering load, wipers, lighter, radio, etc - then all on at once.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
