usually after i fill a full tank of fuel in my car, i start it, then revs go up then drop dying off.
to prevent this i usually peddle the revs for a few seconds to combat it then its fine (and wont die). it only does it if after a filling up with a full tank.
so the question is why does it do that? other than that, the car runs fine.
https://www.sau.com.au/forums/topic/288877-r33-s2-dies-after-filling-up-tank/
similar thing happens to my r32 often.
Do u run the tank dry then fill it right up??
before i found what was wrong with mine i had to refill once tank got half empty because my fuel pump sensor level had broken and was a bit dodgy and if the fuel was moving around in the tank it would trick itself and think its empty and car wouldnt receive its fuel becasue the pump would suck it up.
Jaysiin, my s2 does the exact same thing. Usually the symptoms are worse if I "overfill" the tank, i.e I keep putting small amounts of fuel in after the pump has "clicked" a few times.
yes! i always go a few clicks over. but is there more to that reason though?
and pmr33, got a pic for ya...
Edited by Jaysiin
Try filling it up just to when it begins to click, or even a little under and see if that helps?
PMR33, What is that front bar lip / diffuser thing?! I love it! Tell me more?!
Hahaha nice.
Astro boy: Its a set of Vertex canards, front and side. You can see it closer in my pics: http://www.skylinesaustralia.com/forums/Wh...image73393.html
Edited by PM-R33
you really shouldnt fill your tank up above that first click, however i generally do one click after that to make sure its full and the pump isnt tryin to piss me off, if you fill it right up to the brim (alot more than 2 clicks) what can happen is the fuel will run down the breather tube to the charcoal canister if you run one... and providing the canister is hooked up properly, it can cause the car to run like shit, its what destorys charcoal canisters, you'll know when its gone as you get a fuely smell thru out the car
Hahaha nice.
Where can I get a set of these? How much coin would I be looking at?
i belive its something to do with the preasure in the tank, you know when you open it when nearly empty u can hear the preasure some out. i belive its got to do with this as the tank then has to repreasurerise when the car starts check you carbon canistor that has a vac line that goes to the tank thats ment to do something in that scence of preassurising or de press the tank?
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
