Hey guys,
I'm looking at getting a nice sized cooler since the stockie is kinda pathetic.... Its measurements are 970 x 300 x 70...
My question for you is... am i going to be able to fit that behind the standard R33 Gts-t S2 standard front bar?
If yes then sweet :D otherwise, what bars does everybody recommend, I recently crashed the car so the front bar needs work anyways, so if i have to modify the standard one then thats no problems, just need to know soonish as ive had offeres on the standard bar if im going to get a new one :)
Here is a picture of it :)
https://www.sau.com.au/forums/topic/28888-front-bar-cooler-size/
sound slike someone is trying to sell you an ex truck cooler. Dont buy it. If it was a propper drag cooler it would be around 150 thick also. Bit unless u r pushing 900hp it would be useless anyway.
something around 600x300x70 will fit with a bit of cutting unless u have an aftermarket front bar.
have to understand that bigger AREN"T better, in most case, it is worse.. :thumbdwn:
Hey Dude;
i got my 600x300x90 into my r33 s1 typ M and it was a bit of a bitch. Had to mount it flush against the air radiator removing the original aircon thermo fan and built an entire new bonnet catch mounting bracket. Then i mounted two thermofans on the front of the cooler. You might get the 970 in if you are prepaired to hack away the entrie bumper suport brackets but then you have to watch out for the headlights and such. I say maybe but you better do a lot of measuring befor you start cutting.
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
