Hey guys,
Just wondering, how heat resistant is carbon fibre? Obviously the actual fibre itself is very heat resistant but what about the clear resin coating? Say a rear diffuser is touching on an exhaust is that ok, or will it melt into the coating? I'd rather not have to cut it for the sake of half an inch, but if it is going to melt the shit out of it ill cut it :D Also with regards to cutting it, will it fray the ends? I've drilled into carbon before and it was perfectly fine, but never actually cut the stuff. Any tips?
Thanks
Edited by PM-R33
https://www.sau.com.au/forums/topic/288887-how-heat-resistant-is-carbon-fibre/
it really depends on the quality of the resin, or the clear coat on the top,
carbon fibre is fine with the heat but the clear coating resin and craze or peel off, it wont melt, so id say leave it to let it craze, in the end if it makes it look bad cut around it
It's half installed, ill post pics once it is fully on. It needed a bit of modifying to get it to sit the way i wanted. The way they are made they sit fairly low and my car being low to begin with wasn't a good option lol. So i had to mount it as tight to the body as i could which in turn turned out looking a lot better :)
Yep the PSI parts one :bunny: Gorgeous piece of gear.
Im taking all the pics of fitting for them (up to about 100 at the moment) and writing an install thing so they can use it as a guide for others. There is two main ways to fit it. First way is probably easier utilising all three pieces together but leaves to many gaps and doesn't make the diffuser sit nicely IMO (most likely since it is made for a GTR). The second way is the one i have done which tries to bring it as tight to the body as possbile. Needs more modifying but looks better i believe. I will go through the install in more depth in a new thread once it is completely fitted and post up all the pics.
Here's a couple just to give you a rough idea.
Here's the diffuser:
This is it when we were trying to get it to sit the way i wanted, still being supported by oil bottes :P (i ended up getting it sitting more flush with the body afterwards once the front bracket was modified):
This was the last photo from the other night once it was supporting itself with 4 brackets, the car is still on stands however. Sorry about the night pics, tomorrow after work ill try to finish off the other brackets i want to make up. Ill then take proper pics of the car out in the open and post them up.
It is a 3 piece diffuser and is made to sit with the side pieces supporting the main piece. Personally i didn't like it this way so made the main piece sit up tight to the body and will try and modify and cut the other two pieces to sit them on the outside to increase its length, instead of increasing its height.
Edited by PM-R33
  • 6 months later...
Installation was a bit fidly because i mounted it a bit differently since it is made for a GTR and it sits fairly low the way they mount it. Quality is superb and havn't had one drama with it since installation.
I wrote up a DIY for PSI parts to send out with the kits with plenty of photos of the install.
Edited by PM-R33
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
