Nah, I didnt think so. So ill just need to pick up an aftermarket reg and the correct lines and fittings. Next question, do you have to buy the fitting seperate or is there a kit you can pick up and if not does anyone know what size fittings are required.
Cheers
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4838113
You'll have to buy fittings. I don't know of anybody who makes a kit, but it might be out there. Just look up what the rail and FPR want. I believe I have all -6 stuff. Can you guys order from summit racing down there? I'm a big fan of the Aeromotive stuff, especially their FPR's. I don't really like the Sard or ESPECIALLY the Nismo FPR's.
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4838130
  • 1 month later...
Alrighty guys sorry to bring this thread back from the dead.
Could someone tell me where all the lines go and what other fittings ill need other than the ones listed.
So far ive gathered ill need
2 x 90degree -6 fittings
1 x 120degree -6 fitting
1 x Y piece but not sure if its also -6 and if a barb on each end.
Any help would be greatly appreciated.
Cheers guys,
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4900693
cheapest way to do it would be to only have 1 feed into the fuel rail, block the centre port and have the line to the reg from the other end of the rail. Otherwise you'll need a y block which splits the single fuel line that runs under the car into two -6 lines that feed each end of the rail.
I buy most of my fittings from www.summitracing.com as it usually works out to be the cheapest (delivery is usually between 4-7days). The other place i use is www.mscn.com.au if i need fittings the next day (overnight express post)
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4900767
Not to fused about the price as ill buy all the fittings through my work. Now the line that comes from the bottom of the FPR which goes to the tank how long does that line have to be and what fitting would be on the end of it to join ( fuel tank end ).
Any links to what the y block connection will be like
Cheers
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4900822
Cheers
The line from the bottom fo the reg (return line) will need a -6 45deg fitting that screws onto the reg, and the other end just clamps over the std fuel line. Line length approx. 1m.
These are the y block's i use - http://www.summitracing.com/parts/EAR-100181ERL and then you just use a 3/8 NPT barb fitting on the other end and run rubber hose between the fuel filter and the std hard tubing.
https://www.sau.com.au/forums/topic/288888-hks-fuel-rail/#findComment-4900842
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
