i know its kind of obvious but it sounds like you might have blown a fuse. check all the fuses and if they are all fine then you may have a short somewhere in your wiring. you may have to rip out most of the dash to find it but hopefully its just at the back of your head unit somewhere.
i just fixed up my mates stuffup with installing his headunit and sub. he didnt solder any wires and he missed a few all together. make sure any wires you dont find a use for get some electrical tape around the ends to stop them shorting on anything.
The Clock Died whilst connecting the Wires to the New Head Unit. Has this happend to anyone else? also the Air Conditioning Contols have Died. Cant figure out What happend. Need Help
it`s a 10amp fuse you have earthed power wire at some time during installation
have done it once or twice my self
yep...i did the same just recently..was using my pocket knife to slice some elec tape on the constant power line. Fried the clock.....15amp fuse
  • 4 weeks later...
How difficult is the Stock R32 headunit to remove in a GTR? Is is similar to the R33 headunit guide posted in this forum?
R32 is pretty much straight froward
1. pull up the gear boot plastic trim and take out the ash tray there should be 4 screws 2 behind the ash tray and 2 under the shifter boot
2. then the surround peice should come off
3. there is a bracket holding the HU in 6 screws hold this in, 3 on each side
4. the whole lot should slide out and thats it
i can take pics but mine will be a litle bit different because i have modified my dash
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
