Sadly my gtr after owning for a short time decided to do a big end bearing (what it sounds like). The motor is being looked at as we speak and should have the results of what actually went wrong mid week.
So i had plans to build the engine later on down the track to get more reliable power out of it, unfortunatly the plans have been brought forwards a bit and now i am deciding on what to put in it.
I am going to be putting pistons, sump baffle, not sure if rods are necessary as they have been proven in high hp cars, not really sure on what else needs to be included, have been reading a fair bit but there are a few conflicting opinions.
I want to adress the oil problems that come with the early rb26 (32 1990), i will be putting a baffle in and have read about the welsh plugs at the back of the head that one can be used as another directs drain back to the sump. opinions? other fixes?
What i am after is what you would put and modify in your engine, not going crazy as i am only 18 and not on massive income.
Any advice would be appreciated!
Patrick
Edited by Patrick88
https://www.sau.com.au/forums/topic/288937-rb26-what-to-put-in/
Patrick,
There is a lot of write ups in the Forced Induction section on the main SAU forums.
It all comes down to money at the end of the day.
Lay out a plan of what you will want to use the car for.
Work out what parts will be required to achieve the above mission and then go from there,
Hopefully that can steer you in a direction in regards to budget.
There are a few super tough GTR's kicking around Perth.
So I am sure you will get a ton of good advice.
Also research who you will build with.
Mike
Personally, I'd be putting a 30 bottom end in there but some people are purists :)
Bubba, I'm yet to find a post which does not relate to your RB30 somehow dude lol. Patrick, if you are looking doing it reasonably cheap this might help
Arias Pistons + Rings or CP
Eagle Rods or Pauter
N1 Oil Pump
ACL Bearings
Crank machined
Tomei oil restrictor
ARP headstuds
Hi Octane baffle kit
Head PnP
Block Machined
Metal Headgasket
Shouldn't cost more than $8,000 to $10,000 drive in drive out.
Edited by monga
hahah agreed^^
id go for a spool package..
cps
spool rods
acl mains and big ends and HG
comes in a package
and then
N1 pump
and a standard head re build
get a crank collar
arp heads
tomei restrictor
standard or n1 water pump
and then the appropriate block work
trust sump extension maybe
and maybe some GTss or 2530 or equivelent
Dan
sorry to hear that but very same thing happened to me but was due to the sock harmonic balancer splitting and damaging the crank nose
this is what i did
BOTTOM END
bored
honed
acid dipped $500
Arias pistons
Eagle rods $2000
king bearings (meant to be more forgiving than ALC) not sure $400
ALC piston rings $400
N1 oil pump $600
Tomei oil restriction $15
Tomei sump baffles $300
Ross harmonic balancer $700
had crank, rods, pistons, flywheel and clutch all balanced
ACL race series gasket kit 1.3mm metal head gasket. $500
Nismo mounts $400
HEAD
if you are short on cash you don't need to do this.
Full head rebuild
line bored
oil galleys bored
New valves
15 hours of port polish
Crack tested
Pressure tested
volume marched (also known an CC'ed)
Gates racing cam gears
Gates racing timing belt
Tomie pon cams 260/9.15
Spring tensions tested
New valve guides
Cam covers sprayed bayside blue
OTHER
GT2860-5 turbos
hks 100mm intercooler
HKS actuators
SS manifolds
SS dumps
Apexi PFC
Sard 700CC injectors
all pricing is off the top of my head so are approx
head aprox 5k
bottom end aprox 7k (bullet proof)
extras aprox 7k
expensive yes
but what made it ALOT cheaper i built the hole thing my self with the help of my dad
i has south side engine center do all the machining for me and endless amounts of advice.
Hope this helps i have only put prices for what i recommend you do only do the other stuff if you can afford it
if you what to talk to some one that has just done it them selves for help and or advice give me a call
0433708054
cheers Ryan
Re use 20 year old pistons? Also Eagle rods are about half that price dude :D My first Eagle set cost $1100 or something. Also, all the machining is a must regardless, as you can't smash another set of 86mm again.
Edited by monga
Personally, I'd be putting a 30 bottom end in there but some people are purists :D
I've been meaning to ask you this bubba since your a DIYer and all
Which machine shop do you use?
and do you double check there work/clearances?
Thanks :banana:
N1 Oil Pump
ACL Bearings
Crank machined
ARP headstuds
Head PnP
Block Machined
Metal Headgasket
I agree with most beside the Head PnP (sub 500hp not required)
Add a gasket rebuild kit and water pump :)
Cheers for the advice guys. Havnt been on here for a while hence no replys.
So what i am probly doing is,
CP pistons + rings
Crank linished
Fully balanced bottom end
Keep rods, if in good condish polish or shot peen
acl bearings
n1 oil pump
New water pump
Sump baffle
Oil restrictor
Maybe arp headstuds
ACL Full gasket kit
Not to sure on what the head needs as the engine is being started later this week and still dont really know what condish everything is in.
I have been reading about a oil return you can do with the spare welsh plug at the back of the head. Run a oil line from there back down to the left sump wing. Helps drain the oil back down, also not sure what the go is with the crank collar, Any advice?
Am getting 2860r -5's, new fuel pump, Boost controller then a nistune.
Should have some fun with that combo after run in for a while. Then new tires :D , injectors and re tune get more out of it.
I think haha
thoughts?
Also how hard could you push this combo?
Edited by Patrick88
Whoever my mechanic mate uses (there's only two and it's not Southside) and yes we do double check clearances before final assembly.
P.S. don't use N1 oil pump.. I've jsut removed mine and not happy with the amount of wear after 10,000 odd km of moderate use (lots of abuse but not a lot of power).
I am going to be trialing a set of "splined" oil pump gears for my N1 pump from a trusty member over east, if all goes well he will be supplying to the public.
I also run NDC bearings, quality jap stuff that doesn't cost the earth.
Spool rods, cost me $750 but should handle +500rwhp quite easily.
A GOOD harmonic balancer, personally I have an ATI 1000hp unit to go on.
Thanks for the info Bubba
judging by the amount of people using spool rods 500 would be a walk in the park
JPC make a 4340 billet gear for n1 pumps @ $350
might be a cheaper/faster option compared to the spline gears as we dont know how long it would take to make/test/etc
No probs ;)
I'm really not a fan of the stock oil pump drive setup.. I feel more comfortable trialing the splined drive gears than reusing my N1 pump with the same as stock drive setup.
I should have my splined gears in a week (fingers crossed) and then the testing will begin :D
    • Each province differs a bit but we only do mandatory vehicle inspections here for heavy vehicles (Think Ford F350 and up). Those inspections are done by mechanics that are approved by the government. Besides that, it's a free for all as long as the car looks stock.  I asked because I love seeing how engineering differs from country to country. Here in Canada, all designs must be stamped and signed before they can be brought to fruition. (I.E Bridges, structures, Electrical panels, machines, literally everything shy of a wooden table) This can only be done by a professional engineer or professional engineering technologist. Both are protected titles, but the latter having more of a limited scope in what they can stamp. To become a professional engineer, you must complete a 4-5 year bachelors degree in your field of engineering, be part of an engineering order and undergo 4 years of apprenticeship, testing and mandatory continues education. Same story for engineering technologists, but a 3 year associates degree in some form of engineering technology will suffice. If you do not comply, or pretend you're an engineer or technologist, off to jail you go. If you stamp a design that fails, off to jail you go. If you stamp a design that fails and kills someone (I.E Bridge collapse) Off to jail you go for a very long time, your family will be ridiculed on the news, neighbours will surround your home with pitch forks and your dog will disown you.  Same for specialised trades... Example Electricians must undergo 1.5 years of post high school education, 4 years of apprenticeship, testing and hold proper licences. It's for the best, but then we also wonder why we're so short on engineers and tradesmen haha
    • Not currently, I'm at the school where we teach people to build bridges and other fun things that involve making, or breaking things
    • I have a friend who has used Chequered Tuning and CMS. Went to CMS when Chequered had a long wait time which is kind of the norm (for good reason). Was very happy - I'm pretty sure the very simple thing you're asking will be simple.
    • lol that caught up a year quickly! good to see you on the track again, hoping to do it myself one day
    • Nah he was mega organised, the sort of guy that put (almost) every tool back every day, it made trying to work out where things were up to possible.  My shed needs a swedish death clean, I would have >20 part done jobs, its particularly hard to collect all required parts for a job ahead of time when you can't just pop into a shop and grab things
