epix Posted September 21, 2009 Share Posted September 21, 2009 Hi guys, I remember a RACQ guy rescue me once and he jump stated my car by attaching the cables to somethings under my bonnet. My car battery is in the back. Anyone know what he did there? (1993 R33 GTS-t) Thanks Link to comment https://www.sau.com.au/forums/topic/289000-jump-start/ Share on other sites More sharing options...
ZENNON Posted September 21, 2009 Share Posted September 21, 2009 you sure? maybe he had ground on chassis somewhere and jumped the starter motor directly but that's a bit dodgy.. Edit: Friend just told me usually if battery is in the boot you have distribution terminals in the front Don't know if this is the case with 33s but maybe it is which means he would have just used them.. Link to comment https://www.sau.com.au/forums/topic/289000-jump-start/#findComment-4839382 Share on other sites More sharing options...
r33cruiser Posted September 22, 2009 Share Posted September 22, 2009 Yes thats the easiest way to do it. U use the power cables from the fusebox, and there is a earth. its a flange of metal sticking up infront of the strut tower, it will have a (-) on it. Link to comment https://www.sau.com.au/forums/topic/289000-jump-start/#findComment-4839469 Share on other sites More sharing options...
epix Posted September 22, 2009 Author Share Posted September 22, 2009 thanks fellas. Last time I took the stereo out from the back (custom boot) alot of work putting it back together. Sounds good Link to comment https://www.sau.com.au/forums/topic/289000-jump-start/#findComment-4839492 Share on other sites More sharing options...
BstewyR33 Posted September 22, 2009 Share Posted September 22, 2009 if your battery is in your boot, then you should have something that looks like this in your engine bay Link to comment https://www.sau.com.au/forums/topic/289000-jump-start/#findComment-4839643 Share on other sites More sharing options...
Slow S13 Posted September 22, 2009 Share Posted September 22, 2009 so if i put my battery in the boot i get an RB26.....F*#K YEAH!! Link to comment https://www.sau.com.au/forums/topic/289000-jump-start/#findComment-4839927 Share on other sites More sharing options...
BstewyR33 Posted September 22, 2009 Share Posted September 22, 2009 not quite what i meant................ hahaha *edit previous post* picture used for informational diagramatic purposes only Link to comment https://www.sau.com.au/forums/topic/289000-jump-start/#findComment-4839943 Share on other sites More sharing options...
ZENNON Posted September 22, 2009 Share Posted September 22, 2009 so if i put my battery in the boot i get an RB26.....F*#K YEAH!! lol exactly what i was thinking Link to comment https://www.sau.com.au/forums/topic/289000-jump-start/#findComment-4840096 Share on other sites More sharing options...
Col-GTSX Posted September 22, 2009 Share Posted September 22, 2009 worth noting, there is usually a plastic cover over his area with jap writing all over it... you need to remove this cover (by hand, just pops up when pulled from the right side) and you will see what the photo above looks like... and yes if you pull hard enough you will go blind and think you have an rb26 Link to comment https://www.sau.com.au/forums/topic/289000-jump-start/#findComment-4840486 Share on other sites More sharing options...
