Hi All,
I was thinking about a 30 conversion into my 32 GTSt a little while ago and ran into some difficulty with regards to "legally" doing a 30 swap, mostly around emissions and VASS stuff...
So I have decided to go the path of the RB25DET
Im asking people who have done this conversion: How did you go about getting it to be legal?
If you could please post your issues or successes that you had when doing your conversion/
I dont want to be in a spot where I may have to remove the engine if I get a picky officer unlikely as it may be....
Thanks - also can we keep it on topic - I dont want people saying "Just do the 30".. blah blah blah.
https://www.sau.com.au/forums/topic/289039-r32-rb25-conversion-legal-stuff/
Im also looking into putting a S2 RB25DET into my r32 gts-t too. I rang up a few places and was told that you have to get the engine swap approved by some company in the governmental industry .... and worst of all it was going to cost $900!
Im just going to save my money and get a r32 gtr
VASS varies - place to place.
Enkelman in Braeside are a place i've used, and many friends, their pricing is a bit more reasonable @ $600 ish... $500 cert, $100 brake test.
Either way you need a RWC to cover the basic stuff, and a Engineers to cover the motor conversion and anything surrounding it.
It will help if you have the weight of the motors and so on, although Enkelman are reasonably well versed now being they've done a fair few RB25 & RB26 signoffs now (myself and a few mates).
It should be very easy, i suggest talking to them FIRST however.
See i did things like RB25 gearbox, new diff, brakes and so on... so they could see i'd dont it properly. Not sure if they require the gearbox and similar.
Go down, have a chat, go from there. Should be a piece of piss though.
Hahaha cln - all well and good till they find a diff engine number! I thought about that with the 30 - noone could tell the difference.
Nismoid - Thanks, seems reasonable, I'll be doing similar to yourself in that the gearbox and brakes will be upgraded too so it sounds like I shouldnt have too many issues.
I spoke to a guy on the VASS list, he said I would not need a roadworthy though?
Also what aftermarket stuff did you have? ECU, Turbo etc? or was it all standard to pass the cert?
VicRoads might with regards to the conversion, might not. Just give them a ring. Imports get treated differently to Aus delivered cars as they are "high risk".
I had a standard 26 in there. You should put a standard 25 in, pass that, then do whatever you need (obviously they wont know if you upgrade turbos if they are the same etc etc)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
