Hey folks,
I have a 89 r32 skyline with an rb20de in it, which i picked up pretty cheap as a daily to get to and from uni.
Anyway, recently I've been thinking about adding a turbo to spice things up a bit. I've done a bit of looking around and found you can get a lot of rb20det parts cheaply and it seems i can do a lot of it from home.
I've got quite a few questions, so any help will be really appreciated!
I'm thinking i'll go with an rb25 turbo on a stock rb20 manifold, how do i go about the oil lines, do i have to get a turbo sump or will my stock one be fine? also will i need to get a turbo intake with new injectors? And what about the diff? is it fine to keep the ratio as is or will i have to get a turbo silvia diff? (as the non-turbo skylines are 6 bolt)
Also will a rb20det ecu just plug in and be fine?
is there any major issues with doing this type of conversion?
Yes some of the questions may be noobish, but just trying to get some info. If any body has any links or stuff on how to go about it, that would be great too.
Thanks in advance
Edited by blk032
https://www.sau.com.au/forums/topic/289052-adding-a-t-to-my-de/
check my thread http://www.skylinesaustralia.com/forums/Idea-t288775.html also http://www.skylinesaustralia.com/forums/Re...lin-t69998.html
as for diff, should be fine. ratio wouldnt really matter, turbo isnt going to make a difference to that. you can use your sump but you will have to drill and tapp a hole for the oil retern. the other holes should (might not) have the oil and water points allready they will just be pluged up. not sure if the r33 turbo will have the oil and water in the same spot so you might have to run braded lines.
you will need injectors and a fuel pump. (no point starving your motor) allso a cooler and exhaust. you inlet manifold will be fine. though you will ether need to get the stock metal inlet pipe (the one that runs across the rocker covers) or do some pi** farting around with cooler piping.
you will want to run a pod filter and a cold air intake.
I havent heard of anyone running a turbo on stock intenals from a n/a so you should probably keep it low boot, like 7ish psi.
you could run the 20det computer but im fairly posative you will have to run a new wiering loom for it. but to really get some profomance you should atleast run a piggy back system like emeanage or safc. perferably if you have a manual a powerFC.
as for any major issues, there is allways a rick when your running a turbo on a high comp moter. so a fairly big one would be blowing your motor. thats why you want to keep the boost low. i had a mate who dicided to push 25psi out of his 31 and quikly sent a con-rod straight through the block.
hope i helped panda.
There's a number of us that do/have run it on stock internals. In fact I'm pretty sure I've only seen one (that's posted in the N/A+t Power Results Thread) that has changed internals, and even then it was only really bearings and head gasket.
The biggest issues you will have really is the transmission not coping if you give it decent power and a lot of it, if you absolutely flog it all the time (like any car it won't like it), and probably an even bigger problem... wanting more power and limiting one's self with adding more power, cause as we all know it's very easy to just add more power with a turbo.
i've had a few tuners tell me they wouldn't recommend that. Yes you'll run more boost with lower compression, but you still have DE pistons which have different heat properties etc.. and it defeats the purpose of a DE+t which is very responsive.
I don't believe you'll need a new AFM unless you make it past the limits of the stock one, in which case you would go MAP Sensor or Z32 AFM. I don't know if there's any difference between an R32 RB20DE AFM and the R33/34 RB25DE ones, but in the case of the RB25DE AFM's they're fine for this sort of thing till you start pushing past 200rwkw.
Edit: I'm not actually entirely sure what the precise limit is of the stock AFM, but from what I see it seems that after 200 odd, you start looking at a Z32 or MAP? Someone correct me if I'm wrong, it's late and I'm in need of sleep lol
Edited by N-DAWG
    • Hey guys I don't visit the forums anymore so not even sure how I found this thread but here it is, what a shock.  I'm so glad Neil and Mel got out of Sydney and had some relaxing fun time before this happened.  Neil is a great bloke and will be sadly missed.
    • My OCD says that exhaust is sticking way to far out for a BMW.   Sorry for making you now upset with your exhaust again...
    • That is not true. The R32 GTR wiring diagram is freely available and has been for literally 25 years. And you don't even actually need it because the situation is so simple that you literally only have to use the wire that runs to the original dash indicator. Your car has a problem. That problem is unique to your car. I assure you that if I went out and did it to my car right now, it would work.
    • Thanks man, yes unfortunately normal bar went on after a minor accident. Smash repairer ordered the wrong version, needed my daily driver back asap so just accepted it.  Hoping an aero bar in gun metal grey (KH2?) pops up for sale soon, I know paint from different cars won't match perfectly but will look good enough
    • If it is the case that your stock dash high beam light lights up as it should, all you have to do is tap into the power wire for the high beams dash globe and feed it to pin 25 on the Haltech dash.
