Hey guys, just thought it would be a bit easier to attract some of you N/A enthusiasts to help clear out my shed :(
R33 GTS4 Series 2 VCT N/A Motor rb25de 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Only pulled out for conversion. $700ono includes 4WD Sump and Front Diff, wiring loom and ecu and iridium plugs.
REASON: Took off some parts as I needed them. These include, water pump, tensioner and idle bearings, harmonic balancer, A/C and pwr/steer pump.
Can throw in a gates timing belt used 10,000kms only for $20 if purchased with motor.
R33 GTS4 Series 2 4WD Gearbox will fit stageas as well as any other running 4wd gear including GTRs. 114,000kms in good working condition, however 4th started to slightly crunch after I had oil changed too thin, needs thicker oil and will be ok.
$600ono
N/A polished Induction/Intake pipe, in excellent condition gives a nice low end induction growl. Came off R33 rb25de $150ono
Coby Extractors D12, excellent for N/A skyline, in great condition 2.5'' flange $310ono
HKS Super Drager Cat back system designed speciafically for the N/A RB25DE, in excellent condition check it out on link below.
http://www.skylinesaustralia.com/forums/R3...up-t275336.html
R33 GTR Front 5 Stud Hub Assembly good for 5stud conversions $180ono
Stagea, R32, R33 GTS4 Front swaybar $20ono
Autogauge Smoke Series Vacuum Gauge BRAND NEW $30ono
Stainless steel Cannon Muffler Angle Cut Tip - 2.5'' Inlet, 5.5'' Barrel, 4.5'' Angle cut Tip
Very good condition no dents, came off R33 $45ono
PM if interested thanks guys!
PARTS LIST UPDATE AND PRICE DROPS
R33 GTS4 Series 2 VCT N/A Motor rb25de 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Only pulled out for conversion. $650ono includes 4WD Sump and Front Diff, wiring loom and ecu and iridium plugs.
$600ono
Whiteline Rear Upper Control Arm bushes BRAND NEW. Fits r32, r33, r34, silvias, stageas, cefiro. $85ono
Gates Timing belt used 10,000kms only - $50ono
Edited by OoskylineoO
R33 GTS4 Series 2 VCT N/A Motor rb25de 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Only pulled out for conversion. $600ono take it now or it goes to my friend. Includes 4WD Sump and Front Diff, wiring loom and ecu and iridium plugs.
$500ono
R33 GTR Front 5 Stud Hub Assembly good for 5stud conversions $150ono
Very good condition no dents, came off R33 $40ono
Whiteline Rear Upper Control Arm bushes BRAND NEW. Fits r32, r33, r34, silvias, stageas, cefiro. $70ono
Gates Timing belt used 10,000kms only - $45ono fits rb25de(t), rb20 i think
 Share
