Next year im planning on getting a r34 gts-t and putting gtr parts onto it
GTR kit, wing and maybe some nice gunmetal or bronze CR KAI's
and maybe get the screen housing from a gtr somewhere and just replace it with a touchscreen
would i be looked upon as a poser??
i like the look of GTR's and the power but the $$$$$ sets me right off :)
whats your opinion on this subject?
ohh and do R34 GTR's have wider side fenders? compared to normal gts's?
Edited by Pepsinator
https://www.sau.com.au/forums/topic/289096-gtr-replica/
Anyone with half an eye for GTR's will see right through your attempt to copy one.
And Yes they do have wider front and rear guards......Good luck trying to swap them over..
Edited by GTR-32U
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4840824
Ok then.. ill scrap that
what about putting a R35 front on a M35 stagea like that one made in japan?
how much would that cost?
so i could probably have the first R35 GTR Wagon is Aus ... well sort of :(
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4840852
so i could probably have the first R35 GTR Wagon is Aus ... well sort of :)
Haha, you are funny.
It would cost a lot more than a real 34 GTR. And it would not be an R35 wagon.
As for a mock 34 GTR that is also a shit idea. GTR's are about the drive.. if you can't afford the real thing then don't bother.
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4841060
You'd probably end up spending as much on a gtt anyway, once you finish your cosmetic mods (which wouldn't be perfect), then realise that the car isn't fast enough, so you'd spend more money on that. Just save for a gtr. Or buy an older one.
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4841087
i like the look of GTR's and the power but the $$$$$ sets me right off :D
R34 GT-t's are great cars in their own right. Just buy one of those and enjoy it for what it is.
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4841156
Who are you building this so far fictional car for?
Why ask for opinions on cosmetics from the peanut gallery.........you'll be the one driving and paying for it.
Build it to your own taste, then it will be your car. As long as you like it who cares what the "vogue" crowd think.
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4841662
agreed - just be patient mate, save up the extra cash and get a real gtr :P
or snap up an r32 or r33 gtr, enjoy it, learn to drive it, and then when you are ready and have the extra cash - upgrade :D
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4841674
+1 id have no issue driving a gtt as a daily or weekend car.
basic tuning, remove the wing, with the nismo bodykit and your home with a set of nice wheels
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4842614
i dont get y flamin mongrels try to make there cars be some thing they r not.
gtt's with gtr badges
320cis with m3 badges
any merc with f**ken amg badges
where is the failing going to stop lol
its just sad and u look like a wanka honestly
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4860797
The only thing that annoys me more is when people put 'rival' badges on their cars...
The one that gets me more then anything is here in the shire an old Camry gets around with a GTR badge!!
Like come on!!!!
Edited by gurumaster22
https://www.sau.com.au/forums/topic/289096-gtr-replica/#findComment-4861180
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
