I am trying to find a drift wing for my R33 S2 GTS-T (as in the little lip that makes the boot flush with the rear quarter panels not a fast and furious T-wing) that has an in built led rear light (like the stock S2 r33 spoiler). Mainly because legally you need an eye level brake light and I don't want to have to retrofit one to the parcel shelf.
I have emailed/asked a lot of suppliers and none have had them or even known about them but I have seen one before, I asked the gentleman where he got it from but he said it came with the car.
So if anyone knows where they are available from please post up.
If not, I imagine it wouldn't be too hard/expensive for a bodyshop/fibreglass place to modify one to include a brake light? Any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/289164-r33-drift-wing-with-led-brake-light/
i'm the same mate, tossing up whether or not to get this wing, but i don't want to go through the hassle of fitting another brake light.
i don't think it'd be too hard to retro fit, in fact the r33 GTR wing has the LED strip across the bottom bit.. maybe show one to your panel beater
You only need the eye level light if you have a wing. the DUCK lip/wing is a lip and doesn't require a higher light.
It's not called a drift wing. It got the name by people incorrectly interpreting D-Wing as Drift, when it means Duck.
Also, those are the laws for NSW, but they are a pretty standard law. Go for a drive and have a look for cars that have a higher up brake light. I bet they all have wings or ar station wagons/4wds.
ok so this is wrong. ADR 60/00 says that all passenger cars manufactured after July 1 1989 are to be fitted with a central high-mounted stop lamp.
Link to ADR
OP, i advise you keep looking for someone who can put in a LED strip for you :D
i use my skyline garnish as a 3rd brake light, never had any issues in the 6 or so years and numerous defects.
Find a nice flush mounting LED light - like the R34 ones in teh boot, then get the wing modified. or DIY
If you dont want to try it, find me a nice flush one and i'll try it haha have one of these awaiting install on one of my 33's
Okay so I can't source my own DUCK wing with one built in, looks like I will try and get one made up at the crash repair, hopefully it wont be too expensive$$$ (thanks for the offer of helping make one Craved but logistically it would be easier to give it a shot myself!).
In SA I am pretty sure I need a light in it as my mates Silvia got defected and he didn't have a rear spoiler (original ones have a spoiler with a brake light) so they made him install one on the parcel shelf, same scenario as a Skyline I would imagine.
I will have to try and source an LED brake light possibly a 34 boot style, I have seen the post in this section about LED brake lights for a 34 so I imagine I will use something like that off Ebay, from Import Monster, etc.
Edited by profaine
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
