Well...it's just an air filter lol.
Had to today, booked in for reflash. Sitting around waiting till it's done...so bored =/
Just take the filter off when the dust storm is gone and give it a clean or a few taps against a hard surface and some pressurised air :P
Lol, pretty wicked dust storm though...my v is garaged and it still managed to thinly coat the bonnet and roof of it!
i have one locked up here and its getting inside..
Far =/...no that's heavy duty assault lol
Thankfully none managed to get inside mine. Too pedantic, i'd spend the whole night trying to clean it out.
Maybe go chuck a car cover on it Chris ?
mines in the shed spose i should go look and see what it looks
like wont be as bad as my truck was today started the day at 3am
and it was white drove to moree and back and it was brown man
what a dust storm
Hi guys,
They reckon that tomorrow we are going to be hit with another dust storm. I would recommend not to clean it until next week. Don't forget it hasn't rained here in nsw for like 3 months so the desert sand is extremely loose and dry.
Polish out as soon as possible.
It is funny how you wash your car and then suddenly you find new scratches, it so annoying. I wish there was a paint out there that becomes hard like a rock and cannot be scratched even with a key.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
