Hi guys.
It looks like I've killed the engine in my R33 GTR. (It did a hose, lost all the coolant and cooked itself)
So now I need to make a few decisions on which way to go. Thinking that it must be a sign to get a tough engine built.
Looking for any advise on what to look for - specs / engine buiders / etc etc.
Car will still be a street car, so must be drivable and not attract the wrong attention, but may do a couple of track days.
Hoping to get about 400rwhp (or more). Is this reasonable? too much or too little?
https://www.sau.com.au/forums/topic/289238-gtr-engine-rebuild-advise/
id keep the 26...
not a fan of the 26/30 combo!
mine made 360rwkw with a 26 build
forged internals
drop in tomei cams
-5 turbos
power fc injectors and all the usual mods..
and it was ready for final tune before some F***wit stole it..
if u want more info pm me for people i used for machining and parts and prices etc etc..
i built the engine myself...
not too hard to do if u have an intermediate mechanical mind!
my 2cents worth
ohhh and prior to the rebuild - car ran 11.7 on the 1/4mile with turbos, exhaust and screwed in boost!
so decent build liek what i did keeping the 26, should see it run mid to low 10s and wasnt a pig to drive on the street!
cheerio
Proengines do an RB30 forged short block (bottom end only) for $8000 that includes the adaptor to suit the 4wd sump (your mechanic will then need to transfer the head/sensors/etc from your blown up engine onto that bottom end and install it in the car) . As far as nice to drive on the street engines go the RB30 conversion is hard to beat.
If you only want 400rwhp - It is very cheap and easy.
400rwhp + big/tough motor build = waste of cashola mate.
All you need are the following:
1. Decent rod bolts (stock rods are fine).
2. Some good bearings, ensure the motor is balanced up well and so on
3. Set of forged pistons
4. Garrett -9 turbos
5. Cam Gears
6. Might as well doing some oil control mods. FI Guide has a link for what you need to do (restrictors etc)
7. Injectors, anything 550cc or above
8. ECU
9. Maybe coil packs, depends on the conditon of your current ones so this is the only subjective item on the list
10. N1 Oil pump, factory GTR water pump is ok (make sure you buy a new one)
You don't even need to touch the head if you don't want too for that power aim.
The above build will also easily go upto 450rwhp without much effort. So a bit more than your initial aim, will be nice and responsive as well.
This is with around 20psi from the -9's. Should do it easily and it will run day in/out without a problem.
The above is probably as small of a list as possible for your aim, whilst still making sure the car/setup is very reliable and keeping the costs as low as possible without skimping :D
Things you do NOT need:
1. FPR (fuel pressure reg), Fuel rails etc etc.
2. Garrett -5's - They are 380rwkw+ turbos (520rwhp+)
3. Cams, totally uneccesary
4. 3ltr/RB30 bottom end
5. Head work
6. Aftermarket BOV's, Aftermarket piping kits
7. Bigger intercooler etc etc
FYI - You can run 11.5 on factory turbos if you can drive, been done quite a few times :D
It would want to make it nicer considering the rebuild without it would be substancially cheaper (being he is not chasing big power).
$8000 for pro engines vs what, $3000 for a rebuild of what he has now.
So that's what it comes down too. 3cm higher, I/C piping not lining up, exhaust not lining up - its more cost and effort than just a bottom end change over.
So add another $1000 at least to the pro engines package (im in no way saying its a bad one, its very well priced)
My car drives perfectly fine off boost, and i've owned a 30ET, 25DET, 20DET in the past we well - i honestly don't think for under 400rwkw it's worth the effort in a GTR.
Admittadly im probably 100kg's or so less than a GTR but it's not a major difference. Similar to other GTR's i've been around in with GT-SS's, perfectly smooth around the town.
I have boost building virtually off the line being im using correctly sized turbos for my aim (GT-SS).
Cruising around town is fine as well, no hole to speak of.
If the cam gears and similar are all setup correctly as well as a decent tune which has as much to do with it as any other factor.
If -5's were used, then without a doubt you would feel a bit of laziness in the bottom end with a 26...
However put a NEO head on with VCT which is becoming more common these days - making very interesting things happen :D
Horses for courses i guess and it soley comes down to budget and what you can justify.
For 400-450rwhp, there is no way in the world i could justify a 3ltr in a GTR just for a little better response for over $4000 difference, as that is the only benefit.
Thanks for the info guys.
Next week I will be getting the engined pulled and stripped down to see how much damage there is / how much I can salvage.
Once I now what needs to be done to get running again, then can make decisions on what to upgrade.
Currently budgeting $5-10K. (will have a better idea when engine opened)
Why when its open to work out? :D
The only thing you need to worry about is the condition of the crank. If its ok to reuse - easy.
If not, its only $1100 more.
Otherwise you're replacing bearings, gaskets, rod bolts and all that kinda thing plus machining anyhow.
So that's really the only major factor which i don't think you'll need to worry about.
I'd take an assumption here and say the block will also be ok, even if it's not, nothing major to get a new one (they are cheap) :D
Hi guys.
i think u need to learn how to look after your engine........ how could u not notice losing all your water/coolant? just spending big on a new engine will not stop it from happening again, it will just cost you more!
Yeah he needs to work on his spider sense.... Often the temp gauge gives you no indication of a problem, because there's no hot coolant on it....
did he eva check or replace the hoses in engine bay? probably the originals? prevention is the key!
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
