I am doing a timing belt on an r32 gtst next weekend and have a few questions.
1. The Crank pulley bolt is 30mm?
2. The torque setting for the crank pulley bolt is 142nm then 152nm?
3. Does the crank pulley have threaded holes for a harmonic balancer puller or do you need a puller that pulls externally on the crank pulley?
4. Does the radiator need to be removed?
https://www.sau.com.au/forums/topic/28924-more-timing-belt-questions/
rb25 crank bolt head is 27 mm rb 26 is 30 mm , it has from memory 6 mm bolt holes , u have to take radiator out put car in gear handbrake up then u can undo the crank pulley bolt , turn it a few turns ( 10 mm out ) put the gear puller in place once it becomes loose take the big bolt out and the pulley will come out then .
do it up the same way torque it to 142 - 152 nm but dont worry u wont break it in a hurry .
thats true but dont expect do place the bar on the rail the starter wont have the grunt to undo it , u have to have the bar a fair way from the rail to get a bit of movement firts in order to get it undone .
i undo them with a 3/4 inch rattle gun but not everyone has these .
Surely having the car in gear and hand brake on with my 22" snap on breaker bar and a pole on the end will be enough to undo the crank bolt.
Puts too much stress on the gearbox.
the breaker bar has a lifetime warranty doesn't it? lol .
Of course. Once it breaks, its lifetime has ended.
It's like a "concrete warranty" - once it's off my concrete, what warranty?
The gearbox can take over 700Nm of torque. If you can apply that much torque through a breaker bar, you should probably be in some sort of record book :D
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
