hey guys im from tassie
HELP!!!!!
dont have anyone that can do kits but i did find one i f***ing love
but..... they want $2050
for the bonnet side skirts and front bar :(
this is very exy and was wondering if anyone knew where i could get this
i left a picture here plz help me guys tassie sucks for parts and there isnt enough nice skylines down here which im trying to change thanks.
have you tried carmate.com.au yet?
that is the fake 400R AU Spec version
i had a proper jap version on my series 2. they do look different from the front. i had mine fitted before the car left japan. and in the two years i owned it i couldnt find one distributor in australia that sold it or a version that looked just like a real 400R front bar.
Are carmate bodykits straight bolt of fit or do u have to stuff around with them mate i want decent quality but no stuffing about
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
