Hi,
Have the following ugrades:
-K&N Induction
-3 1/2" catback Exhaust
-Apexi PFC D Jetro
-GT2871R Turbos
-Turbosmart Boost Controller (set to 1.2 bar)
The power is not as good as I hoped it to be. Any advice?
Have just purchased a Nismo fuel pump and 600cc Injectors hoping that'll make a difference.
Also need help tuning the PFC since am running it on the base map.
HELP!
https://www.sau.com.au/forums/topic/289274-r34-gtr-tuning-help/
You're going to need:
- Exhaust Gas temp gauge
- Wideband O2
- Datalogit
- Dyno time..
or pay Unigroup to tune it for around $500~$1000
Base map and upping the boost = trouble
Edited by johnnilicte
Thanks for the tip.. Trouble is living in Africa proves to be abit of a hassle when it comes to ordering aftermarket parts. Many ppl don't ship here.
As for tuning experience, I have a tuning shop here and have produced fairly good results with evos & stis.
Had a Supra RZ just before I got the GTR and that was a breeze to extract big power out of. The GTR seems to need alot more to make serious power.
Yeah a better designed cylinder head and an extra half litre capacity will do that.
Have you done any head work?
Also, why 600cc injectors with 2871 turbos? That combo should be good for over 700hp so 600cc injectors aren't going to do it justice.
How much power did you make at 1.2 bar?
Dan.. I guess ur right about the Supra.
Haven't gotten any head work done yet. The thought of dismantling that head worries me abit.
As for the 600cc injectors, was looking for drop-in replacements by Nismo and that's the best I could get. The others were sard and tomei but needed modifications or new fuel rails which I didn't want to venture into at this time. Placed an order with greenline 2 weeks ago and still awaiting goodies to arrive.
What kind of power should I expect with the setup I plan to run? Was hoping for something in the region of 600.
The absence of dynos in this city make it difficult to makeout exact horsepower. But the fact that I manage to keep ahead of the Evos & Stis, I assume I should be in the region of 400
I hope you are talking 400kw? Standard turbos can do 400hp almost. That setup will see you to 600hp at the wheels but make sure your tune and fuel system are both up to scratch as these two items will let you down if you're not careful. 600cc injectors are a tiny bit small for the turbos so monitor your afrs closely and make sure you don't push it past their capability.
Guilt-Toy confirm what equipment I'll require for the distance tune and what you charge for it?
Was thinking of purchasing the wideband O2 sensor kit from Innovate motorsport and the pfc datalogit.
Suggestions anyone?
Make sure the wideband device you purchase is a good one, and has 0-5v afr output so we can connect it to Datalogit.
the price is about $350 usd to tune this car. if you fly me to your country I can bring everything with me. the datalogit and the wideband sensor needed to tune your car. I am in Georgia in Eastern Europe so it will not cost too much to fly you there. Maybe you can find other cars that need tuning as well and we can work something out.
I normally charge $300 - $500 usd for a tune. Remote or not.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
