For Sale - R33 26/30 780hp ... Qld
Item: 95 Skyline R33 Gtst
Website:
Item Condition: Good
Price and Payment Conditions: $55,000
Extra Info:
Paint - PPG Custom 3 Lay Candy
Interior - Recaro's
Rims - 20 Inch & Spare Slicks
Engine -
26/30 Fully forged built engine
HKS T51R
Hypertune Plenum
Fully built head , 294 Apexi
Tomei Oil Pump
Bar & Plate custom intercooler
MSD Ignition
Microtech LTX12 Engine Management
Gearbox -
B & M 2 speed glide
5000rpm stall converter
780hp at the RW.
Car has been featured in HPI.
Also won best street paint at the last powercruise.
Please pm if you would like more images sent.
Pictures:
Contact Details: 0412 120 620
Website:
Extra Info:
Interior - Recaro's
Engine -
HKS T51R
Hypertune Plenum
Tomei Oil Pump
MSD Ignition
Gearbox -
B & M 2 speed glide
780hp at the RW.
Pictures:
may i ask why you are selling?
cheers mate
 Share
    • normally i don't like to get involed with these kinds of self promotions stuff, but good on you for living your dream man.
    • Remember our cars are 30+ years old so expect the rubber bits to leak. I'd go around your engine bay with a can of "start ya bastard" or similar and look for leaks. FYI I got my car 10+ years ago with the standard boost restrictor in place, I removed it when I got it and the car never had any issues since (besices a leaking manifold gasket). tl;dr- Look for leaks before proceeding.
    • That SSR is actually the same (or similar) as the Jaycar 100AMP SSR (which I use). They suggest the resistor to stop the SSR turning on when the ECU turns off (I believe). I personally don't use the resistor as I use the 5V output from the ECU to supply power to the SSR. I do however run a flyback diode, the old Haltech documentation was wrong too and didn't specify the fly back, I mentioned it to a few of their staff and they eventually added it in.
    • I did manage to do this without removing the engine or front cross member, but I had the advantage that the exhaust manifold was removed. I am not setup to support the engine from the top or remove it. 1. Loosen the engine mount nuts so they only have a nut of thread. If it is a manual, I think you have to remove the gearbox to engine support brackets. 2. Jack up the engine off the bottom idler mount. Jack it up till the end of the slot and nut on the mount. You need this clearance to get the pan out at the rear of the engine. 3.Break the sealant seal to sump. I found a oil pan separator tool helpful to get it started. 4. The oil pick up can be removed with the gap available.  5. The oil pan can be removed now. 6. Before assembling, do not apply sealant to the oil pick up area as your hand will rub it all off but apply to the other three and a bit sides. 7. It is a two man job to put the oil pan back, with the sealant, as you do not want it to touch anything and rub off. 8. With one person supporting the oil pan the other can fit the oil pickup 9. Apply the remaining sealant. This would be more difficult with the manifold or turbo in place, but I think it could be done. As you can see my sealant is a bit ugly, but good enough to seal. 10. Lift the sump up to the engine and bolt it on. We found it was easier to use two long guide bolts at each end to get it nice and aligned without touching.
    • I find building an exhaust a really satisfying job! Looks nice!   Did you consider using an oval pipe to get the same cross sectional area but keep it above the chassis rail?
