Just be careful. I have seen some pretty crook ones around second hand, and still fetching 2K+
I am not trying to say DoughBoy is going to sell POS turbos;), as he has already sold a few second hand turbos here and no bad feedback, but just be careful if buying second hand that you know what you are getting and get it from a reputable/trustworthy source and remeber you get what you pay for.
Edit: and new you can pick up a new 3037S 56t for aound 4k +/-. New in Japan they sell for around the 3.5 mark.
Amosite, I have to wait on a few things before offering them up for sale. I want to dyno T51R vs twin 3040 vs twin Apex'i before determining which setup i'll keep. But so far looks like the 3040's are a bit big.
Steve, I guarantee any parts that come through here. The last thing I want to sell is some faulty goods (it's happened to me a few times and I would rather not pass that experience on to someone else).
No probs, like I posted, I didnt want to give the impression that you were, so sorry if I did.
As I said before, although I havent dealt with you personally, plenty of people have, and I havent heard a bad word - which speaks volumes for your integrity:)
Just trying to warn amosite not to buy the cheapest turbo, cos they cost more in the long run - alot more
What would be the used price of one of these turbo's?
Have you tried Kristian at [email protected]
I have bought a HKS 3037S and Volk wheels through him. Very good proces and excellent service. He advertises in this forum
why don't you try Mark from Banzai Motorsports;
Email:[email protected]
PH: (07) 55294621
Mob: 0405 183215
i know that he has both the HKS GT3040 and a HKS GT3037 Pro S (T03 flange with internal wastgate).
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
