  • 3 weeks later...
Here's my bit for SAU Community Service:
http://www.nitroware.net/~tony/mines1.jpg
http://www.nitroware.net/~tony/mines2.jpg
http://www.nitroware.net/~tony/mines3.jpg
http://www.nitroware.net/~tony/mines4.jpg
They're big but it's readable. The pics are kinda odd though with strange moire, pincussion/screendoor artifects but this is a cheap Acer scanner.
T.
