ive recently put an rb26dett into my gtst. converted to rwd running a s2 r33 box. i sent it in to 1 of out tuneing specialists. they wired the the hole set up so it worked. then i took it back there and had it run up on their dyno. they re chiped the factory rb26 ecu. since its been sitting 4 nearly a year as it is not road legal yet ive been geting it ready 4 cert. ive since driven it a few times. put new fuel in it. found that under boost it cuts out. so i tried a new igniter and loom. still farting around. so i got rid of the coils and put in a wasted spark set up thinking it was a doggy coil. its still no better. it wont boost higher than 0.5 bar then seams like fuel cut or boost cut. but that has all been removed when new chip was written. the timing is all correct and hav brought up the fault codes and everything it working fine. cleaned afm and they r mint.
if any 1 could maby point me in the right direction that would be great
https://www.sau.com.au/forums/topic/289388-rb26dett-conversion-into-a-gtst/
sounds like a nice project.
Have you upgraded the fuel pump?
also try a set of afm,s that you know work.
just because there clean it will not always mean they will work correctly.
that would be a good place to start i think
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
    • Nice, love a good GTS-t.  IMHO the factory body kit with the 'aero' front bumper is perfect. Can't improve on it unless it's a GT-R. But it looks like you changed it to the normal bumper?
    • Easy solution to both of those. Put a split bit of garden hose on each one. Attractive and practical!
    • So I guess the next thing to do will be to discuss whether to create a new section of the forums to hold the library (boo hiss?), somewhat undoing the recent tidy up, or if there is a bolt on wiki module for Invision? (I must profess ignorance as to what has been done, what it might cost, etc. I have only briefly googled and seen discussion on adding it.) Or is a wiki even the best way to do what I'm talking about? It possibly isn't. Given that we're trying to re-display forum content, it probably needs to be presented as forum content in forum format, and a wiki would probably struggle with that. A wiki might still be the best way to do some other things, so I'll keep the idea simmering if we don't use it here. Back to the library as "part of the forums". Would we do a single new library? Or put a library thread in each section? Pluses and minuses for each of these, surely. Would we do as I originally suggested, and make the first post in the library be the total of the library, with any reply posts just being the inputs and suggestions I originally posited? Or would we allow posts to accumulate one after the other, each containing additions to the library? Maybe the first post is still an index or something. It's all sounding horribly more manual and messy than my original brain fart. But I hope there's some other good ideas floating around - because every time I come up with a new one of my own I immediately see problems with it.
    • Tips look fine to me......but Boring stuff: Legalities - Vehicle standards notes that exhausts cannot extend to a point where they could cause injury Scary stuff: Mrs cuts open her shin putting stuff in the boot (ensure you have some bandaids and shiny jewellery handy)
